Rapido 2006 door light (1 Viewer)
Silver-Fox
9,269
29,128
Cheltenham Spa
Rapido
im a not so newbie
Ok folks
I have some forward movement oo err :)
The overhead lights that work when you open the passenger door us two cables as belo pic.
The Brown is live till you open the door then goes zero voltage
The black is permanent earth
Question is what wire from the tk103 tracker do I fit to the (presume) brown wire from the door
Red and black goes into door brown and black to lights
Silver-Fox
Silver-Fox
9,269
29,128
Cheltenham Spa
Rapido
im a not so newbie
Looks like I'm struggling on this one :(
I would mail the supplier but I don't think my English would convert well to Chinese :D
Oct 29, 2012
887
1,045
essex
Rapido 9090df
20 years (unless you count my dads VW which makes it 52 years with a few gaps!!)
I don't know what model you have but mine are fixed under the drop down bed, as reading lights. the problem was that they go off 10 minutes after turning the ignition off as they are linked to the battery saver to prevent flattening the battery if left on.(they are originally the courtesy cab lights) I rewired mine to the habitation lighting circuit so I can actually use them! If you are wiring a tracker you need a permanent live. sorry I cant be more help.
PeteH
6,853
9,032
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
If you are still looking for a permanent live in that area try the radio yellow? Feed which is behind the radio installation.
Silver-Fox
Silver-Fox
9,269
29,128
Cheltenham Spa
Rapido
im a not so newbie
Thanks for the replies.
It seems I may have explained things incorrectly maybe?
No problem with the lights at the front in the cab, all works ok etc etc
No problem with the permanent feed and yes used the radio feeds.
My problem was i needed either a positive or negative feed that activates the cab lights in the front.
From the front door i have a permanent earth so can use that, unlike old school door switch.
Now the live is only live with the door closed as soon as you open the door the voltage has a large drop and the interior lights come on in the front of the cab.
The tracker needs a feed to tell it to work from the door either a positive or negative, there are two options with the tracker.
That is my problem :(
