Radio without ignition (1 Viewer)
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Finally!!! got the thing to work by running a pos from the leisure battery via a switch, snipping the ignition supply to radio and connecting the leisure supply. Bob's your mothers brother. :thumb:
movan
21,492
120,753
Moving around
Burstner
since07
Wish I understood the above posts.... that's what I wanted so I bought a little battery radio at the bring and buy....:Eeek:
You men have no idea what it is like to be a woman in a man's world of plumbing, electrics, batteries etc:cry:
Rainbowchaser
325
5
Third rock from the sun
Err..A blue one
Hmnn...Quite a long time really...
Oh, so us men do have some uses left then Joy?
I explained all this to you before woman!
You take the two radio wires, bare the ends and attach them to the flux capacitor terminals. Whatever you do, don't let the live wire touch the bodywork or the whole vehicle will melt into the tarmac. Connect the torque ejector splines to the flange casing and ensure the 50 jiggawatt fuse is in place. Switch on, and the smell of burning electrical insulation will dissipate in an hour or so.
Hope this helps...
If not, get a man in!
:winky:
Munchie
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Not that difficult Joy. I drilled the dashboard in a suitable place (just beneath the clip board on mine)
Put a switch in. Then run a lead from the pos on the leisure battery (with an in line fuse) to one side of the switch.
Now the complicated bit...on the Euro plug into the back fo your radio you will find there are two supplies, one for the memory and one for the radio.Supply these from the switch and oorf you go.
Mine was complicated by the fact that I have a powered ariel which also has to be powered from the leisure battery.
::bigsmile:
bigfish
348
84
Eastleigh, Hants
8 years, but had caravans & Tents before that
You take the two radio wires, bare the ends and attach them to the flux capacitor terminals. Whatever you do, don't let the live wire touch the bodywork or the whole vehicle will melt into the tarmac. Connect the torque ejector splines to the flange casing and ensure the 50 jiggawatt fuse is in place. Switch on, and the smell of burning electrical insulation will dissipate in an hour or so.​
Hope this helps...
If not, get a man in!​
:winky:
Thats not quite right, you forgot the, Flux drive impulse inverter, :RollEyes:
Sorry the misses spoted it:Eeek: , she made right this up for the ladies:thumb:xxx
43,348
49,546
::bigsmile:
if you powered both these from the new switch how do you retain the memory when the switch is turned off Ken ?
movan
21,492
120,753
Moving around
Burstner
since07
HUH! That's easy .... but I'll let Ken explain.
