Quick question! (3 Viewers)
Feb 26, 2013
1,653
9,437
Pinar de Campoverde, Spain
Giottiline T60
Since March 2013
We had to have our solar panel removed and re-fitted today as we had a leak where the cable comes in the roof. The fitter advised us not to drive for 12 hours so we are parked on an Aire round the corner from the service centre. It has been raining on and off since and more rain is forecast. 12 hours doesn't seem very long and will it take longer to go off in the damp/wet conditions. When would you say we can safely drive further south in search of the elusive french sun?
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
Depends on what sealer he's used, I would get him back ASAP to sort it! you don't want water in your roof, you never know where it will end up, and the damage it will cause.
Cheers, Dave:thumb:
Coolbeanz
Feb 26, 2013
1,653
9,437
Giottiline T60
Since March 2013
Cheers, Dave:thumb:
Not sure you understood my question. It is all sealed now and was done at a Hymer dealership (don't even ask what they charged, I'm still raging about that one) but my only concern is how long before we can safely drive? P.s. It was silka 222
11,956
16,571
12 hours is more than enough. It will still harden further but after 12 hours you can consider the panel immoveable.
haganap
12,766
26,479
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Fitted mine in the morning, By the afternoon I was 200 miles away, and I've just checked out my window and its still on nearly 3 years later, and my sat dish, :thumb:
go now, go forth and find the good weather
:Cool::Cool:
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
Oops, sorry mis-read uour post. Glad all is well now, just keep an eye on the inside roof for damp appearing in the future, as I said it can appear anywhere, depending how long it's been leakiing for.
Cheers, Dave:thumb:
haganap
12,766
26,479
planet earth
Cheers, Dave:thumb:
you never know, poor coolbeanz could be posting its leaking tomorrow, in that case your more than justified :winky:
17,637
43,375
sika 222 will form a skin within an hour, then will set fully within 4 hours. then over the next few days it will form a polyurethane rubber type compound. if the fitter used accelerator on it, the sika will set even quicker
i would say give it 4 hours before putting too much force on it, 12 is overkill
once the skin has formed rain water wont affect it
11,956
16,571
What idiot fitted the entry grommet under the panel :roflmto: :Doh:
I do. I don't use any of the (poor) entry systems normally available. I use a short section of threaded plastic pipe with nuts tightened against the inner & outer skins & leave a 25mm upstand above the roof surface. The cable is sealed where it leaves the pipe using polybutyl tape but water will never get near it because of the upstand and the fact that it's protected by the panel. Panel - roof recommended clearance is 50mm anyway so the space might as well be used for something. What is of more concern is a panel fitted so it can't be removed without destroying the adhesive: mine are fixed to their mountings with threaded fasteners. The mountings are fixed to the roof using Sikaflex.
