PVC Rear door hinge (1 Viewer)
Jul 22, 2023
21
36
Burnham-on-Sea, UK
Devon Aztec
I have a Citroen Relay panel van conversion. The rear doors only open to 90°. I would like them to open to 270°, or even 180°would do. Is it possible to achieve this by simply changing the hinges or would I have to replace the doors? Thanks for reading.
Oct 29, 2008
5,095
6,025
West Yorkshire
They usually break the rear door windows (if fitted) when opened back.
There is usually a push button in the door card to release further
4,173
5,162
Market Rasen
Since 2003
You will not have to change anything, the converter may have just covered up the mechanism that at the moment holds it in place. I covered mine up but you should have something similar to the picture below.
5,095
6,025
West Yorkshire
Thanks for the reply. There is no push button on mine.
Can you relase the stay thats between the door and body, some vans have a release on them?
Or as yours is a self build is the mechanism from the button behind a panel?
5,095
6,025
West Yorkshire
You will find a round metal hole in the inside door skin. The button would be fitted into it pushing the release.
The button may be there behind your panel. If not you can buy them quite cheaply and fit them
2,139
3,821
worcester
Sunliving van
The top metal arm in the photo is what controls how far the door will open.
There are 2 types. One will allow full opening (you may break your door windows if you do). With a stop at 90° that needs the button pressing to go further.
The other restricts opening.
When I wanted to fix mine to 90° both type were available on eB. I just put a bolt in the arm.
374
422
Gloucestershire, UK
Burstner Eliseo C602
Since 2016
This is the position of the button in relation to the stay.
And this is the back of the button
So you can see how it simply pushes in to release the first stay position.
  • Nice One!
Reactions: f6c
Silverman
Jul 22, 2023
21
36
Burnham-on-Sea, UK
Devon Aztec
Right, thank you. I've been able to pull the door covering away far enough to see a hole where the button should be. So if I buy the buttons I should be able to open the doors fully?
Although it seems people are restricting theirs to 90° because of possible damage to windows. Maybe I should leave well alone.
374
422
Gloucestershire, UK
Since 2016
I guess it depends on the size and design of your windows. Ours are flush and come nowhere near the bodywork.
374
422
Gloucestershire, UK
Since 2016
Unless the window is open and a strong wind catches the door as you open it.
That's why I restricted mine to 90°
Not sure I would be trying to open my door 180 Deg in strong wind and would the window be open in such circumstances? If the window was open, I am next to it and can easily shut it.
I only normally open it 180 Deg if I am loading, cleaning or carrying some maintenance. The windows are also on self locking struts so not locked open firmly.
Anyway, the OP can decide the benefit Vs risk.
