Power supply to charge 12v UPS battery (1 Viewer)
Ridgeway
3,666
6,176
Lausanne
NiBi Arto 85E
This one's a bit off topic/forum but I know there's some knowledgeable 12v people on here so thought it worth an ask.
I have some battery back units that i use in my aquarium system, these are 12v batteries just to give a few hours pump circulation. Now some how I've lost the PSU's for them, I can only assume they got thrown away in clean up campaign.....
Now checking on the manufacturers website they do a replacement that is 14.v 1.6a but no surprise it's very expensive so I'm looking for an alternative but and here's the question can I get away with using a 12v PSU instead of the 14.5v original ? I assume the 14.5v is for the same reason that car alternators give out much more that 12v so in my theory a 12v PSU would work but perhaps wouldn't get the battery to 100% of it's potential.
I have plenty of spare 12v PSU's so i can try it assuming it won't damage the battery ? the original replacements are £50 each :-(
11,956
16,570
You need 13.8v to maintain a 12v lead acid battery. Check the PSUs you have as you may find one with correct output. 12v wil not work.
2,347
10,197
If I understand correctly, you are looking for a charger that you leave permanently connected to the batteries ?
If so, I would use the 3 way smart battery charger that Lidl sometimes have on offer.. at around £14
Ridgeway
Ridgeway
3,666
6,176
Lausanne
NiBi Arto 85E
Yes this is correct although the charge socket is a 3.5mm jack plug socket so I'd have to adapt that although it does seem like a reasonable solution. So it looks like I need a 13.8v charger with 1.6a or more, cool.
Ridgeway
Ridgeway
3,666
6,176
Lausanne
NiBi Arto 85E
I was pretty sure they were as they weigh around 20kgs each but I checked on the manufacturers website and they are described as that, but it was worth checking.
Think I get 2 of these battery chargers as described above and just solder on a jack plug
