portable solar panel chargers (1 Viewer)
belboy
76
33
N/Ireland
Elddis
Hi All : I'm looking for some advice on these chargers please
Been looking at them on amazon
need to know if anyone who has one, or knows anything about them could point me in the right direction------i.e. are they any good for the keeping the leisure battery topped up
cheers in advance
Bellboy
GJH
29,450
38,827
None, now sold
2006 to 2022
All depends on the power rating (link to the ones you've been looking at would be useful) and whether or not you can keep it oriented towards the sun (especially in winter).
I tried one of Link Removed a few years ago when I knew nowt and was daft (as opposed to knowing summat and still daft :Smile:) and found it to be useless.
B
belboy
76
33
N/Ireland
Elddis
Many thanks for the reply GJH---sorry not as switched on with the old PC as you matey----don't know how to attached links
Wivvy's dad---that's the very boy I'm after ( the brief case one)
should I look at anything else or is this all I require to keep the leisure battery topped up mate ?
Belboy
wivvy's dad
3,205
1,795
48.066895,12.862673
Transit LWB Hi-Top PVC
On and Off since '98
Belboy
I'd say go for it. You can always point it towards the sun, which is a bit trickier with the roof mounted jobbies, and cheaper, and you don't have to drill holes in the bodywork.
I got the leads hard wired onto the leisure battery rather than the alligator clips supplied.
scotjimland
2,335
10,108
A Woosh bang
Max power is less than 1Amp ... to be exact 743mA
that is in FULL sunlight.. at best, it will keep a fully charged battery topped up, providing it's not being used.
scotjimland
2,335
10,108
A Woosh bang
Which is what the OP asked, unless I'm very much mistook
no.. that's correct..
but didn't see 'fully charged' in the op question ...
I was just clarifying.. sorry I mentioned it.
Douglas
2,835
400
South Wales,
6 years + 5 years in boat before that
In my opinion 1 amp at max, and I stress MAX charge of 1 amp and that's only available for an hour or two on a sunny day (unless you stay with it and move the panel every hour) is not even going to to keep up with self discharge of all but a brand new battery.
Doug...
43,331
49,464
just one point to remember with that panel.....
Please note: This kit is not waterproof. The panel is water resistant so suitable for use in light showers but the charge controller unit should always be kept away from moisture as it is not water resistant.
which will mean taking it indoors every time it rains or it could get waterlogged and fail.
it seems Amorphous panels are not waterproof.
I nearly bought a 60w panel from maplin's a few years ago...had to ring and cancel the order once I realised.
Sep 23, 2007
1,710
1,970
Leicestershire
4 and many as a tugger
For the same money as the maplin folding unit, you could buy a 40 watt panel c/w a digital charge controller from flebay.
Feb 4, 2010
2,329
1,590
Mid. Glamorgan, S. Wales
Motorhutch / Toy Camper
Since 2010
Are you saying the panel's themselves are not waterproof or the whole unit because of the controller? The charge controller is a separate box that clips via short leads to the battery and is meant to be fixed inside the vehicle. There's a a single cable (something like 1.5 - 2m) that connects to it from the panel. So in my case when it's rained the panel has been the only thing outside.
To reinforce what others have said...don't expect much from the 13W Maplins panel and you won't be disappointed. It definitely won't keep up with the drain from my compressor fridge but in decent sunlight it does stretch things out. And on a very sunny and hot day in June last year (yes, we did have one), when I flattened my battery it keep the fridge ticking over enough to keep things cool enough inside.
