Portable Sat system HELP REQU'D PLEASE !!!!! (1 Viewer)
wingman
1,217
3,333
Romford, Essex
Coachbuilt Lo-Profile
Help/advice required. Due to another Funster asking questions about Sat TV, I got mine out to try.
Despite trying almost everything, I cannot get my satellite system to show more than 83% on the signal intensity and 14% on signal strength (as monitored on the TV satellite setup page). Here's the checks made so far.........
All connections checked/double checked.
Dish feed cable swapped
Receiver boxes swapped (I have a working spare)
Voltage to LNB checked
TV Scart connections checked and swapped
I've also linked up a small portable case-type that I have as spare and done similar checks with that system.
I'm aware that minor movements of the dish are required and all of the paraphernalia that goes with set up BUT, there's hardly a damn signal to start with, let alone moving the dish milllimeters at a time!
A signal strength of '14' remains, even if I unplug the lead at the dish end!!! The result is the same on both kits and the case-type worked ok before, even in the garden which is where I'm trying it all out now.
Anyone any ideas I've wasted a whole sunny and hot day!
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
patience is required, wait until you get out of the channel tunnel BEFORE setting it up:thumb:
On the other hand maybe the LMB is shot or more likely you are setting up on the wrong sat.
Traveller_HA5_3DOM
422
323
Following the Sun
Hobby Premium 65GE
since 1985
Look for the simple things first, you do not have the right elevation in all probability. We have all been there. Recheck your elevation, take into account any slant on the van if parked on a slope, then start searching from the east swinging back towards where you think 28.2 is. Some tuners will take longer than others to digitise the signal so be prepared to wait each time you move the dish. Also remember if you are inside the van with your compass it may be influenced by nearby metal or electrical objects.
17,645
43,461
i gave up using my compass and now use my phone with a dish alignment app
as for the fault, it sounds like a dodgy LNB assuming correct alignment
wingman
wingman
1,217
3,333
Romford, Essex
Thanks for the help Lads.
The fault was a combination of a dodgy feed-lead to the dish and ummmmm operator error! (Needed to elevate the dish a bit more).
Of course, one problem always begats another. Now got a triffik picture but some channels - like Sky News/BBC etc - are in 'CinemaScope' (if you're old enough to remember that). There's a gap at the top and bottom of the screen. Curiously, some film channels are full-screen.:swear:
I've played around with the both remote controls in case I've entered an odd picture size but all is normal.
I also get the same 'thinish' picture using my spare receiver box.
Any ideas?
Traveller_HA5_3DOM
422
323
Following the Sun
Hobby Premium 65GE
since 1985
Glad you sorted it. Astra 1 at 19.2 is such a strong signal I find it frequently seems to be where I am looking for Astra 2. But at least having found it you do know that 2 is just a few degrees to the east. 28.2 is the setting on the mean line, degree 0, so as you travel east or west it seems to be in a different place. Also because of this they seem to be at a different height, this is due to the geostationary orbit following the earths curvature so again needs to be taken into account. The furthe East the lower on the horizon and to the west higher. Then of course because the satellites are all above the equator the further south you travel the higher on the horizon they will be.
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Go into the tv menu you will find there are different aspect ratios i.e. 4.3 etc. Try each one till you have a normal picture.
P.S. turn off any "auto" picture function!!! :Smile:
