Poor MPG (1 Viewer)
OddSocks
475
386
I was expecting better. Not millions but just better than this!
1990 Mercedes 208D 2.3l - 21.8 MPG for the last few tanks.
I have been trying to drive sensibly! Not going over 60mph. OK, lots of hills in Devon and Cornwall need 3rd or even 2nd gear at times...... but seriously! Under 22 MPG?
Am I expecting too much, or does this sound a little low to you?
BTW - I tried the premium fuel. Made no difference. Felt like a I had a bit more power, but the exact same MPG I got with standard diesel.
ETA: There is an after market turbo and inter cooler in it - could that be the culprit?
Les
Apr 18, 2008
301
4,229
Seaford
Low Profile
I had 208d non Turbo go any where "SLOWLY" up hills 25mpg
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
my 508d only managed 17mpg I'd guess 22mpg about right for an older Merc. My sprinter based Merc does 24mpg, your van is lighter so maybe you should be getting a bit more but not a lot.
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Sounds right to me. Mine gets 10mpg (on propane). That makes it about the same cost to run per mile as yours.
11,932
9,097
22 mpg Sounds about right to me :thumb: you won't find many vans doing much more than 25 mpg with a big bump on there heads :winky: The turbo will help increase the mpg simply with the increase in torque IE not having to change gears as much and being able to leave it in the higher gear for longer
terry
longdog
Banned
Apr 16, 2013
255
287
I had an '56 plate CI Cipro 55 on a Mercedes Sprinter base with the Sprintshift 'box. Driving like a nun I was averaging 20mpg worked out on mileage and reading at the pumps.
Now I have an '09 Ace Adventurer 635EK with a FIAT 130 multi jet motor. I am averaging just over 25mpg or 25.2mpg if you want to be pedantic. Ironic when you consider the Ace has a Luton body too.
My old Hymer Swing with a FIAT 2.8jtd was more economical than the Merc and the Hymer had a Luton body too.
I think the Merc is just plain thirsty to be honest.
OddSocks
OddSocks
475
386
Thank you everyone. Being new to all this I just don't know what to expect.
I will keep tinkering with different fuels and additives and see if we can't tweak another couple of m's per g! :)
Nov 18, 2011
11,862
43,046
Planet Earth
A van
Over 25 year's
maybe take it for a tune up that may help get you another 2/3 mls PG
maybe the pump is running to rich get soume one to have a look
11,932
9,097
::bigsmile: slow down to 50 mph that will give you a couple more mpg :Smile:or do some free wheeling down those big Cornish hills ::bigsmile:
terry
Jan 4, 2012
2,242
2,023
somerset
Fiat Ducato
A few years now
It`s a wind problem--
Last year i drove 65 miles down the M5 in a 45 mph headwind and averaged 10MPG--foot on the floor :Eeek:
On the return journey x2 days later ,the wind was still there ,45 +mph tailwind and averaged almost 35 MPG
A motor home has a slipstream coefficient value the same as a side of a warehouse.
It hurts when you travel to a site in a headwind ,then have a headwind on return :cry:
Feb 16, 2013
19,739
52,051
uttoxeter
ambulance conversion
50 years
Had the van version of this, didn't do any more mpg than yours and you've got a bigger body on yours
43,334
49,533
tweak away....but you wont get it.
All this rubbish about super duper fuels is just that....rubbish.
All they have is more additives to burn cleaner and increased cetane.
How Does Cetane Number Affect Engine Performance?
Just as there is no benefit to using gasoline with an octane rating higher than recommended for a specific engine by its manufacturer[HI], using diesel fuel with a higher cetane rating than is required for a particular diesel engine design yields no bonuses[/HI]. Cetane number requirements depend mainly on engine design, size, speed of operation and load variations--and to a slightly lesser extent, atmospheric conditions. Conversely, running a diesel engine on fuel with a lower than recommended cetane number can result in rough operation (noise and vibration), low power output, excessive deposits and wear, and hard starting.
Regular diesel has a cetane number of 48....premium is 55.
Your engine was not designed for premium diesel......and was probably built before premium diesel was thought of.
Emmit
8,034
17,754
Pilote Explorateur
Jan.2014
Greetings,
I've not tried this with the 'van yet (Hobby 650 2.8 Fiat lump) as it's all too new (getting 27+ at the mo!!!)
But,
when I was tugging I put in 250ml of 2 stroke oil in a tank of 70Lts of an Audi 2.5 Tdi. I swore it made it run better. One things certain, the 2 stroke won't hurt it. Give it a try. The Audi has 165000 on the clock and is as sweet as.
Regards
Mar 29, 2011
961
639
Rugby UK
C Class RS
I have a 3litre manual Hobby and drive at 60 - 65 mph using cruise as much as possible,I get between 18 and 23 acording to the wind speed & direction, if the 200l water tanks full or if I have my trailer on, the variable's are endless, I have give up checking it now :Doh:
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
I remember a couple of posts back the OP was given guidance on chip fat :Blush:
I believe that fuel efficiency is something that has to be put to one side when owning and driving a coach built or a-class MH.
Perhaps a day van or larger van conversion gives better MPG?
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
Greetings,
But,
Regards
I put 2 stroke oil in my sprinter-based Autotrail, haven't actually checked mpg yet but recentlly done348 miles (full tank) and still have 1/4 tank left. We are away next Sunday so will fill-up and check mpg then. Ireckon on 20+. Thats with sprintshift g/box and using cruise as much as poss.
I also think the engine seems to run smoother and quieter too, got the tip via a Land Rover forum a while back. In a test (in the US I think) they compared loads of additives and 2st gave about 7percent increase in mpg, others did nothing and a few were better, unfortunately I can't remember the best performing ones!
Cheers, Dave:thumb:
ps, thats with a toad too
Portland
923
1,424
Conwy
20 years
Hi, I ran these Mercs as luton delivery vans and they returned 15/17 mpg local deliveries and 18/20 on long runs. I took them to various tuners but to no effect. Don't waste money on Premium fuel it will make no difference. :thumb:
lee52
327
119
tyne and wear
selfbuild
newbie
I dont even want to think what MPG I will get with a 26yr old 6.7 cummins with a 6ton brick for aerodynamics
2,346
10,189
I can tell you.. about 12 mpg :roflmto:
I had the 5.9lt Cummins in my RV pushing 8.5tons , it did about 12 mpg .. maybe 14 on a good day downhill with a tail wind .. :Smile:
I stopped working it out, too depressing .. just fill it up, 70 gals worth and enjoy the drive.
lee52
327
119
tyne and wear
selfbuild
newbie
the cummins have cracking exhaust note
lee52
327
119
tyne and wear
selfbuild
newbie
you never know I might get more mpg less weight and the bigger engine wont really be working
2,346
10,189
don't they just.. :thumb:
I used to love driving through tunnels.. the Dartford tunnel was ace .. drive with the window open just to hear the rumble that only a Cummin six has .. I do miss the old girl..
Morocco , Sahara .. can you guess what flag is flying from the aerial ?
Les
Apr 18, 2008
301
4,229
Seaford
Low Profile
I have Cipro 55 on 2002 Merc 316 3500miles round Spain motorway and non motorway 25 / 26 to gallon
lee52
327
119
tyne and wear
selfbuild
newbie
love the pictures awesome
OddSocks
OddSocks
475
386
Too many peeps to thank individually, so :thumb::thumb::thumb: to all.
What I can take from this thread:
It aint runnin too bad at 22mpg! :Smile:
No point wasting any more cash on premium fuel.
It was well worth running that RedX through a couple of weeks ago. (This is probably why it seems to be running better on the premium, it is clean now!)
You guys are great! :thumb:
Probably not worth trying this then? Broken Link Removed
11,843
14,080
Probably not. Two stroke does work to an extent though. I use it on my Discovery, just around a third of a litre to a tankful, gives about a 3mpg improvement.. The theory is that it replaces some of the lubrication lost because all the diesel now is low sulphur. The Discovery forum reckons it will keep your turbo and particulate filter (if present) cleaner also and tends to reduce emissions.
edit make sure it is mineral (not semi or synthetic) oil though. I usually use the Tesco one.
MattR
4,105
38,997
Beds
Panel van
Years
Our Merc Sprinter La Strada 312D P plate Auto has returned 28mpg when on long runs (averaging around 60 mph) and down to 21mpg when in the Highlands and Islands of Scotland with lots of hills and short journeys.
17,635
43,366
basic maintenance is the key to running an old diesel efficiently. that and the occasonal use of a dose of 2stroke to help with lubrication. to save money use a few litres of vegetable oil to bulk the diesel out at a much cheaper cost
no way are you going to see better mpg figures that will be noticeable. people have wasted a lot of money chasing that goal before
