plywood verus hardboard (1 Viewer)
lee52
327
119
tyne and wear
selfbuild
newbie
just a quickie
just wondering why 3mm plywood is used for ceiling and wall panels apposed to 3mm hardboard
Minxy
32,700
66,738
E Yorks
Carthago Compactline
Probably because plywood is stronger than hardboard! :Smile:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
I would imagine hardboard would sag between fixings
No doubt Terry will be along in a minute with a pro's answer
but do not be surprised if he says "cause hardboard is sh1te"
284
172
South Wales
swift kontiki
I'm a newbie bought our first motorhome 7months ago and love it
Plywood is more stable less prone to sag due to opposing grain in the board
L
lee52
327
119
tyne and wear
selfbuild
newbie
am using ply anyways was just wondering thats all. Didnt think about the sagging knew it wasnt as strong screwing things to it etc...
TheBig1
17,655
43,500
hardboard is made from wood pulp so no grain and takes up moisture and swells. plywood is thin opposing layers of wood with a natural grain bonded usually with water resistant glue.
ply has a greater structural strength too
treetops1
1,599
1,759
yorkshire/ lincolnshire.
Sold last van-
a long time,since 1996
Most caravan manufacturers used to soak all hardboard so when fitting would dry flat and tight .Not sure they still do but it certainly worked.
Terry
11,943
9,144
Lincolnshire
Can't remember ;)
Well here I am::bigsmile: hardbord will bow between fixings ::bigsmile: and like John said it's sh-t needs finishing and although very strong under compression not much else going for it :Smile:
if you can wait a few days until I get my van and I will post tips and what to do with the roof to stop any bellying.When I eventually get it I will only be a day ripping out what the nutter did and will have the insulation along with the new inner roof in along with pics -- lots of pics:thumb:
terry
Oct 28, 2013
490
443
Lincoln
Van Conversion
I didn't know you could even buy Hardboard now.
What's it used for these days?
As a kid I remember my old man (an incorrigible DIY'er) dry-lining room after room with it in our old house and even building cupboards out of it.
I'm not sure Plywood even existed back in the early 1970's.
Terry
11,943
9,144
Lincolnshire
Can't remember ;)
That's because it was cheap ::bigsmile: If your old man made cupboards from it I bet he made a traditional frame(2 x 1 etc)and covered it with HB --ply has been around for about 100 yrs :winky:--I think MDF has taken over from HB -that too is heavy but if kept dry it does not warp,shrink or move :Smile:Weight alone will keep it out of a M/H
TERRY
scotjimland
2,427
10,588
A Woosh bang
TERRY
indeed.. just had to look that up...
In 1797 the Englishman Sir Samuel Bentham applied for patents covering several machines to produce veneers. In his patent applications, he described the concept of laminating several layers of veneer with glue to form a thicker piece – the first description of what we now call plywood.
an interesting history of plywood.. .. http://en.wikipedia.org/wiki/Plywood
I have a Singer Sewing Machine Cabinet, partly made from plywood , dates from 1917..
More Photos herehttp://scotjimland.blogspot.co.uk/2012/06/singer-drawing-room-cabinet-no-21-with.html
Broken Link Removed
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
That is a beautiful Singer example SJ and a wonderful restoration job (I assume you had to restore the cabinet). We inherited a somewhat more utilitarian, and probably younger, version from my aunt; the base is a simple open format with drawers at the top. It is now with our daughter but I have to admit that the veneers have lifted in some places (corners) and it looks a bit the worse for wear. She likes it though and uses it as a general stand (until recently for an aquarium).
We still have the machine in the loft.
Terry
11,943
9,144
Lincolnshire
Can't remember ;)
Jim will take it off your hands releasing room in the loft for more junk ::bigsmile:
PS I have not yet started to throw non throw away crap in my loft still got a little room left on and around my pool table ::bigsmile:
terry
scotjimland
2,427
10,588
A Woosh bang
Hi ... thanks, tis indeed lovely example..
wish I could claim that it was all my work.. but no restoration.. just a good clean and polish .
I stripped the machine head and cleaned and oiled.. and as they say.. she runs like a sewing machine..
if you look at the blog you will see a few more of my collection.. It started out when I bought an old Singer to do some work for the RV.. I fell in love with them.. I also have fond memories of my grandmother sewing on her treadle.. she was a tayloress, as were several other aunts and family members..
here it is sewing..
[ame="https://www.youtube.com/watch?v=9WZwsRsxiPc"]https://www.youtube.com/watch?v=9WZwsRsxiPc[/ame]
and some more..
[ame="https://www.youtube.com/watch?v=-pNbwaiXVTE"]https://www.youtube.com/watch?v=-pNbwaiXVTE[/ame]
12,269
45,078
Norfolk
Two wheel job towed.
Since 2004
Plywood stays flat as a result of its cross laminated structure and is lighter than hardboard which as already stated can sag between fixings.
In a potentially damp application use WBP plywood not MR .
