Peugeot boxer (2 Viewers)
Bat and ball
41
25
Coach built
Hi funster , I am trying to find out how many Peugeot boxer owners , that has had front wheel bearing problems, my failed on the first MOT at 8000 miles I was told by the garage it is out of warranty , The wheel bearing has failed again at 16,000 miles , this is very serious and dangerous,
paddyd887
38
31
great barford
pvc
We have a 2008 Boxer and have completed close on 50k with no problems with the front wheel bearings. I would advise that you contact Peugeot Customer Care direct and insist that you are given a case number. Explain your problem to the assigned Resolution Manager, in the past I have found them to be very responsive and have "out of warranty problems" either totally done F.O.C. or at a reduced cost.
Best of luck.
Bat and ball
Bat and ball
41
25
Coach built
Thank you very much for your reply , we have contacted Peugeot customer care on Friday they have given me a ref number , when the wheel bearing failed at 8,000 miles customer care informed me, that the vehicle was out of warranty they did not offer any help what so ever , I have spoken to other owners and they have the same problem on n/side front ,
Many thanks
Paul
DuxDeluxe
14,659
72,818
Planet Zog
A woosh bang van
As above - yes apparently not uncommon. We had our 06 Ducato front wheel bearing fail at 6000 miles. It might be something to do with it sitting around a lot, either awaiting sake or when in someone's driveway etc., but not an expert so just supposition
17,635
43,369
its that common, that i know of at least 2 people that carry a spare bearing and carrier when they go abroad. its not unknown for the bearing to be seized in the carrier and that breaks when you try pressing out the bearing
the parts are relatively cheap and having a spare means that its only a few hours labour at a garage to resume your holiday
extra300
9
5
Malton
Nearly one year!
Higuys. Had the front n/s wheelbearing fail at 22000, shortly after buying the van. Our s is a 55 plate Ducato . Luckily we were only 6 miles from Elgin, and when we took it to the Fiat dealership there, (Arnold Clark) the mechanic said they had done several, all of which had been stood for a long time. Ours had done virtually no miles in the 7 months before we bought it. His advice was to ensure the van was driven for 15/20 miles at least, every month. They changed the bearing under warranty, we followed the mechanics advice, and 2 years and 6000 miles later, there has been no repeat of the problem.
11,956
16,570
Another occurrence that kills them is negotiating deep standing water. Warm hub suddenly cooled sucks water into the bearing. I've seen them go within a month after that happens. Might be relevant given the weather in recent years.
Bat and ball
Bat and ball
41
25
Coach built
Hi Dux Delux , many thanks for your Reply when my failed at 8,000 miles first MOT Peugeot said the vehicle was out of warranty and did not want to know Price of repair £378-00 it's has gone again at 16,000 miles the same wheel bearing it seems to be A very serious fault which could cause a accident,
Paul
DuxDeluxe
14,659
72,818
Planet Zog
A woosh bang van
Thanks for the reply - there are many tens of thousands of these vehicles on the roads so it probably isn't a design fault. As above, you have probably been unlucky. Many people don't have a problem, but a few do. We were one of them, but the van when new had stood in Brownhills for many months. As Big one says.....it happens. Enjoy the van and don't worry about it. It isn't dangerous as far as I know. Just noisy......
Bat and ball
Bat and ball
41
25
Coach built
Hi tony ,
We had a ford transit and we never had wheel bearings go on that one in nine years of ownership this is obviously A manufacturing fault which
Peugeot is ignoring,
Many thanks
Paul
17,635
43,369
Hi tony ,
Many thanks
Paul
good luck getting them to admit it though. if replaced when it starts making a noise it should be quite safe.
DuxDeluxe
14,659
72,818
Planet Zog
A woosh bang van
No issues with the last van and I don't expect any with this one. Both Fiats, which are identical to the Boxer/Relay. Not worried about it, to be honest. It is a minor issue and life is too short........... don't mean that in a bad way, just trying to put it into perspective a bit
Jan 4, 2012
2,242
2,023
somerset
Fiat Ducato
A few years now
There is a idea that the over head cab area acting as a high up weight swing from side to side can be transmitted to extra side stress on the front bearings, they were not designed for this originally as a pick up / van , as the weight should be in the back only.
Badknee
7,408
413,037
notloB
Vantage Neo
Living the dream.
I had a Relay with this problem, they first changed the steering rack, then the anti roll bars, and finally the bearings. I spoke to half a dozen drivers that had the same faults.
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
I always thought that manufacturers use similar bearing suppliers, so there shouldn't be a problem with the bearings themselves, more likely a suspension angle fault or as joner says, the high roof stressing the suspension/ bearings with extra weight.
Our Boxer based van has almost 12000 on the clock in 15 months with silent bearings all round, maybe you need to use the van more
