Peugeot Boxer Battery "recall" (1 Viewer)
wingman
1,217
3,333
Romford, Essex
Coachbuilt Lo-Profile
Does it look from my photo that the incorrect battery has been factory fitted??
It's a 2014 MH with a Peugeot cab.
Cor...... What a job to get at the battery compartment. Take the cab carpet up (plus another one fitted on top to save the original from mud) then millions of plastic twist 'screws' on the cover plate - not to mention doubling myself in half to get at it all!
It's all experience though, just in case I ever need to get at the battery in future.
Anyway, does this mean I get a FREE new vehicle battery?
wingman
1,217
3,333
Romford, Essex
Cheers @Jaws
I'll tell you what.....this forum never never fails to amaze me! Apart from all the MHF discounts and two free new full Calor Lite cylinders, it now looks like I'll be getting a £120 battery FOC. All for a tenner subs eh?
Before I get too euphoric, here's another pic where it says 12v 95A. (Partially hidden under the negative terminal lug). Not a very good pic because I was trying to hold up the cover plate wiv me 'ed! It's a bit confusing. Am I still in for a freebie batt' ?
Nov 30, 2009
6,548
149,138
Pickering
PVC the PUG
I'll have to show this to Ralph.
He upgraded the battery, in as standard, when we bought the panel van. But it's a 2014 model. I'll get him to check . Just incase.
Cal54
3,807
62,118
Southport, UK
Leisuredrive Renoir
Since 1996
I have a 63 plated Boxer and not sure if this is appropriate for my age of van - not relishing trying to find out given the comments made by wingman above!
23,836
72,598
Cheers @Jaws
It is the 680A that is important Wingman. That is def one to be changed.. no doubt at all
Simple enough.. if you have a fone with a camera on it poke it in at roughly the right place and take a picture :)
Apparently in could affect vans back as far as 2012
Been doing a bit of digging.. It actually goes back in to 2011 by the looks of it !
golly
golly
2,006
69,660
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
I checked my battery, it is the 680A type, contacted dealer, didn't know anything about it (surprise surprise) so I phoned Peugeot customer services. Gave all the details to the person who answered the phone, initially she said it did not affect my vehicle, but when I said I had looked and the battery was 680A she said she would pass it on to someone else, I was given a ref number and should get a phone back within 24 hrs. Will keep you informed.
wingman
1,217
3,333
Romford, Essex
@Cal54 Dont let me put you off. It wasn't that difficult; I just exagerated a bit to add flavour to the saga :D
My Boxer is a 63 plate too.
As you probably know, the battery resides under the nearside floor of the cab (where the passenger's feet go). If you lift the carpet that side, you'll see a plastic cover plate. Unfortunately, this cover plate extends to the middle of the cab floor, so it's easier to take the carpet out.
Undo the plastic 'twist screws' half a turn with a coin and lift off the cover plate to reveal the battery. There's a further small cover over the negative terminal. Depress the plastic lugs inwards and remove this terminal cover too. This gives you a better view of the battery specification/description (see my photo in my initial post). Take a snap with phone or camera, then reverse the process. It didn't take me too long really (n)
Oh. There are two tabs on the leading edge of the cover plate. Make sure you locate these in the corresponding slits before tightening everything down.
PS. Thanks again Jaws.
madgeD
259
480
Cleveland
Van conversion
since 2005
I read this yesterday on MMM, we rang the local Peugeot Dealer who did our first service, sent them a copy of the bulletin , we are waiting for their response they didn't know anything about it so I suppose they are trying to verify it with Peugeot.
Cal54
3,807
62,118
Southport, UK
Leisuredrive Renoir
Since 1996
Thanks wingman, it is a job I will tackle tomorrow and then have a word with my local Pug dealer. I anticipate they will no nothing at this stage judging from previous posts!
madgeD
259
480
Cleveland
Van conversion
since 2005
Well ours didn't We have been asked to take a photo of the battery send them it for their records , then they will order one.
rich g
480
855
Worcester
A/S Warwick
since 2013
I have just phoned Peugeot and got exactly the same reply golly had so we will see what transpires.
:whistle:
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
This smacks of a con/scam to me. If Peugeot were really doing a recall on batteries why would they not send out that letter to ALL parties who may be affected? Also if it were real why when people have contacted Peugeot have they been told "we know nothing of this"? The typo in the apparent letter is repeated 3 times, which in itself leads me to suspect its validity. "680A" and "950A" refer to the batteries ability to supply large amperages (680 A = 680 AMPS, 950 A = 950 Amps, these are what is known as cold cranking amps, i.e. the batteries ability to provide big current in cold conditions) The reference to 950 AH (repeated 3 times) is a measure of the batteries capacity. I find it difficult to believe that a company as big as Peugeot, who build very technically complicated vehicles would issue such an inaccurate recall letter to just one person. Also the very fact it was copied from another forum leads me to doubt its validity.
D.
Lillylo
10
Warwickshire
Bailey Autograph 740
I'm a newbie
Just checked our 2015 Bailey Approach and we have the 680 battery also. Just about to go away so will have to sort it on our return. Can someone post a picture of their battery compartment with the lid off. We have had some extras fitted and I'd like to see what a standard set up looks like so I can see what has been wired in to ours and where. Ta
golly
golly
2,006
69,660
HYMERCAR PVC
since August 2009
D.
Well if it is a scam/con, its all over the forums, caravan club, auto sleeper owners, MMM, etc. Peugeot will be really pi$$ed if it is.
11,935
9,106
No it doesn't, the other pic clearly shows 95Ah. That's the storage capacity, the 680A is the cranking amps which must not be enough for a cold engine.
I would think 680a CC would be enough to start any 2.2 engine -I think my old 2.8 ltr iveco only needed 650 cc
plus why only pugs Citroen share same production line so I would think they share same battery
terry
paulmold
892
302
North Wales
7 year (25yrs a tugger)
And several Autosleeper forum members have already had their batteries replaced or booked in at Peugeot dealers for replacement.
One member rang the number quoted, was promised a reply by email (so he had it in writing) and this is the reply received
Thank you for your recent email, in relation to the battery in your Boxer
Motorhome.
I can confirm that if you have found that your Motorhome has the 680A battery fitted and not the 950Ah battery and would like this to be changed.
Please take your motorhome along to a Peugeot franchised dealer, who will check the battery and look to replace it with a 950Ah battery under your
manufacturer’s warranty.
I’m sorry you have had to contact Peugeot Customer Relations under such
circumstances, but I would like to thank you for bringing this matter to my
attention.
Yours sincerely
Emma Tombs
Customer Relations Manager
10,123
18,394
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
if the later battery hatches are the same as my 2007 there are only two twist locks to open, those nearest the seat on the plate there are some others but i think they hold the battery box in place the otherside ie nearest the front is just two lugs similar to the battery hatch on small electrical items
Kool Kroozer
1,361
2,228
Cannock Staffordshire
Low Profile Hobby Premium
Always learning
Our battery was replaced by Peugeot under warranty as it was not holding its charge, this was after only about 3 months old from new (63 plate) think i will take the cover off in the morning an see what they replaced it with .
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Motorhome.
attention.
Yours sincerely
Emma Tombs
Fair enough, I stand corrected. It just seems odd to me that they'd make suuch a glaring error 3 times in the same letter and why isn't this letter being sent out to all owners?
D.
eddie
8,163
41,309
Taunton Somerset
RV
since 1989
Do they provide a trailer for the 950Ah battery?
It certainly wouldn't fit it the battery compartment lol
It would be the size of nine and a half Banner 100Ah batteries, which have a testing rate of 440 CCA (Cold Cranking Amps) BTW
Good luck :)
paulmold
892
302
North Wales
D.
Apparently as it's not a safety issue, it is only being directed to converters who in turn should be contacting owners. Maybe the larger battery is only provided on vehicles destined for conversion and standard vans come out with the smaller battery. I agree the typo is a very poor mistake to be sent out, obviously not checked by whichever department issues such letters but that sort of proof-reading mistake happens all the time these days.
wingman
1,217
3,333
Romford, Essex
@Lillylo Here's a pic of the battery compartment with the main cover plate off (and the smaller negative terminal cover removed).
Pic is a bit fuzzy, but should be ok?
Hope this helps
James
golly
golly
2,006
69,660
HYMERCAR PVC
since August 2009
Update
Got the phone call from Peugeot this morning as promised, they said that, yes some vehicles had been fitted with the 680A battery, but it will work fine in my vehicle ! When I suggested that there was a big difference in the "cranking power" (thanks @hilldweller) and that I used the van all year and didn't want to be stuck in a field in November with a dud battery, she said to take to a dealer who would double check and replace with 950A battery under warranty. Quite painless really, they obviously are trying to limit the number of batteries they replace, and to be honest I haven't had any starting problems, but I am contacting my nearest Peugeot dealer for the replacement asap. Got a follow up email to show dealer, its exactly the same as the one posted by @paulmold, with the same typos.
John
Cal54
3,807
62,118
Southport, UK
Leisuredrive Renoir
Since 1996
I am getting the runaround from Peugeot re the battery issue. Understandably my local Peugeot dealer knows nothing of this issue and so I rang Peugeot customer centre direct. Basically they will not confirm there is an automatic recall but that it has been deemed appropriate for the Bailey MH's. They will not accept a photo of the battery in situ, and I have been advised that the vehicle must be looked at by a Peugeot tech and then they discuss the matter Direct with Peugeot. Couldn't get an answer as to why it was only appropriate to Bailey and Auto sleeper!!
madgeD
259
480
Cleveland
Van conversion
since 2005
The latest is our Peugeot Dealership has asked for the mileage which we have given her 9.950 she said she will probably have the new battery in by Tuesday ! so she must have been in contact with Peugeot as they have asked for the photograph of battery and now mileage.
Carol I see you have an Alto like us, what year is it? we contacted the Dealer that we had our first Service last year with, not 100 o/o sure they are doing it yet , but will be annoyed it it should be done and it isn't. I think like anything else the main supplier likes to deal with the Dealer so it might be an idea to find a different one than the first one. I copied and pasted that Bulletin and e.mailed it to the Peugeot Dealership I would try that if I were you.
