Peeling Alloys (2 Viewers)
Sep 28, 2015
2,018
2,615
Hymer B544
2001 Caravans 2011 Motorhomes
Anyone else have this problem on their alloys? It was new July 2014.
Feb 22, 2011
9,800
20,201
Newcastle under Lyme
Hymer B544 A Class
Sorry, don`t know the answer but that is very disappointing on a two year old vehicle.
Is it worth contacting the dealer and asking them to contact the factory / wheel manufacturer and see if they are willing to do something ?
Might be a known issue
Otherwise there are companies that can refurbish them - at a cost !
Gellyneck
9,244
18,334
More than toes wet now!
Not on motorhome but on car.
Hyundai replaced them under warranty so might be worth a call to dealer \ manufacturer.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Your not alone,many cars on the road today are suffering from this problem this type of finish has been failing since 2006 on the Chrysler 300c
It seems the more that fail the more Manufacturers copy this crap system (the Alloy is too highly polished to hold the clear Laquer)
They can be re done circa ÂŁ90 a wheel but they dont last either, far better to paint em
Chipster
1,008
1,121
East Midlands
Getting there!
Afraid that's not unusual for diamond cut alloys. I've had several cars with that type of finish and always ended up getting them powder coated. It only needs a stone chip or heavy handed tyre fitter and the lacquer will be chipped.
Scotties
439
318
Hymer
Not just a Hymer I think all the Burstner ones have peeled to, they've agreed to replace them on mine but have been waiting nearly a year because of the scale of the problem. See your dealer :whistle:
Wilderbeast
92
85
Stockton on tees
"Hymer duomobil" B634 SL
Since 2011
experienced exactly the same with our last Burstner replaced under warranty a well documented issue should be replaced without any hassle
Mikey RV
4,905
24,269
Devon
Burstner Elegance I821G
Since 1977
My Burstner wheels are the same. Emailed Burstner in Germany and they said to contact uk dealer for warranty work or good will. Will see how I get on.
sparky
97
85
bingley yorkshire
a class burstner aviano i
30 years
Hi my burstner wheels are the same going to get replaced in 3 weeks time under warranty 2 years old I have friends on there 3 rd set all ready they now fit fiat alloys to the new burstner song
MC 55 FUN
3,432
6,347
Rural South West Wales.
2015 Majestic 195
Since 20th Feb' 2016
I've witnessed lacquer peel on pretty much every diamond cut alloy, caused by a stone chip or similar.
Hettie's Crew
Sep 28, 2015
2,018
2,615
Hymer B544
This doesn't appear to have been caused by stone chip damage, it looks like it starts around the bolt holes and 'worms' it's way along, lifting as it goes. They are unaffected around the outer parts of the wheels and the spokes. Even though I understand why it may be happening, I find it unacceptable that this should be the finish on wheels. They must be more durable than this.
Tim
MC 55 FUN
3,432
6,347
2015 Majestic 195
Tim
If not stone chips it's possibly / probably caused by simply tightening the wheel nuts which cracks the lacquer & then moisture / road salt / grit etc seeps under & lifts.
May 9, 2011
145
223
Cheshire / Vale De Parra
Rapido V55
Since 2011
Same on my Hymer, all four wheels corroding round the bolt holes, replaced under warranty, I was told they were on back order, I had to wait 3 months for replacements
Hettie's Crew
Sep 28, 2015
2,018
2,615
Hymer B544
Did you get the same type of wheel as replacement? My concern is that it happens again, unless something has changed with manufacture. How long have you had the replacements and are they doing OK?
Tim
May 9, 2011
145
223
Rapido V55
Since 2011
Tim
Same type of wheels, only had them fitted two weeks, so not proven yet . I guess there will be a warranty on the new wheels.
(did not ask the question) as my original alloy wheels started to corrode after 6 months from new.
Cheers
53,487
150,255
Friends Carthago had the lacquer peeling at under a year old, they had had problems with wheels supplied by a British manufacturer he was give a choice of wheels for the replacement.
laird of Dunstan
1,464
3,953
lincolnshire
Rapido 9000DFH
ex caravanner
I thought that the manufacturers would be wise to this now, laquer or clear coat as its known in the industry will not stick to a metal surface with any longevity, i used to refurb alloys ,i would give the owner the option of either a painted finish or a powder coating on the wheels.
makems
3,440
27,716
Ingleby Barwick,,Teesside
Sadly had to give up
We had this problem on our then new Burstner after just a few months. It looks a bit like a fungus growing under the clear lacquer.
Ours were replaced under warranty.
They look identical to the Hymer wheels except for the logo on the centre
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
It looks like the person who fitted the wheels was heavy handed with the wheel nut gun and scratched the laquer while fitting the nuts.
Whatever the cause, it's disappointing on new wheels, hope you get it sorted soon
11,956
16,570
It's a very old problem. Alloy parts on '60s & '70s Japanese motorcycles had the same finish - mainly engines, fork sliders, hubs, and brake-plates. The 'cure' we all used at the time was Nitromors to remove the lacquer then decent aluminium polish. Hard work to keep it up but it looked much better than the lacquer ever did.
Aug 27, 2009
19,788
23,077
Hertfordshire
40 years
Diamond cut can be a bit of a pain when you damage them too. All paint and lacquer has to be stripped then put on the lathe skimmed then painted and re lacquered. If it is a deep cut it can be filled before skimming. I have the odd one done, low profiles are a pain. They come up like new though. (y)
sparky
97
85
bingley yorkshire
30 years
Hi you might get 12 months out of them and they will do the same Burstner/ Hamer now fit fiat alloys because of this problem
Hettie's Crew
Sep 28, 2015
2,018
2,615
Hymer B544
Accepted as warranty issue by Hymer, though they are supplying the same wheels and Lowdhams say there is no warranty on the wheels outside of the two year period for the vehicle which will be up in July. I won't even get them until August. Best put some decent wax on them straight away.
