Oyster Vision system help. (2 Viewers)
PhilG
1,582
4,089
leicester
euramobil 810
since birth
Have a day to sort this out before the hammer goes through it ...
Bought van , has oyster system on it , dish goes up and down . wont acknowledge receiver is connected to allow search to start. What instruction there are, are shit .
Any ideas ??
dabhand
4,307
23,936
Staffs
Concorde carver E35
Since 1993
Has it got the receiver and is it connected?
dabhand
4,307
23,936
Staffs
Concorde carver E35
Since 1993
Is dish searching or just going up and down?
PhilG
PhilG
1,582
4,089
leicester
euramobil 810
since birth
yes its connected but i dont know if its any good or not. just got sky reciver out and it still asks for that too.
23,836
72,539
Up on to the roof and disconnect the coax cable
off the roof, plug in and turn on the sat receiver
Take a meter up on the roof.
CAREFULLY** check end of coax to see if you have about 15 volts coming out.
If no, make up a short lead with a plug on one end and tother end striped off and in pig tails.
Plug short lead in to the place on the controller the dish normally goes to and check again
If voltage there then duff bit of coax from controller to dish
As a matter of interest, have you tried the sky box back indoors ?
If it has stopped working there now, then you have a short circuit in the coax somewhere and it has blown the small fuse in the sky box and proly the one in your other receiver too !
Be very careful. If you short out the coax it will blow a fuse as above
PhilG
PhilG
1,582
4,089
leicester
euramobil 810
since birth
That all sounds very complicated.
The dish goes up and goes to its last position ok , but that's it .
I haven't tried the box indoors , it worked , as did the 12v one I am trying.
as for checking the voltage.. that's above my pay grade. LOL
23,836
72,539
The box may well work, but there is a small separate fuse inside that protects the gubbins if you get a short circuit on the coax
Shame you are a bit of a trot away.. Would take about 10 minutes to check it all out for you..
If you fancy a drive though, you are most welcome :)
PhilG
PhilG
1,582
4,089
leicester
euramobil 810
since birth
Appreciate that , I will have a look when I get home and try not to blow myself up.
I may borrow a new box from my dad , and see if it sees that one , or blows it up. LOL
Jul 29, 2013
9,071
18,565
Salisbury
Hymer B678DL A class
Ours just says satellite mode on the control box then just switch on sky box and tv and away she goes
Jul 29, 2013
9,071
18,565
Salisbury
Certainly not meant to be piss taking thought you might like to know what another Oyster system says on its controll box sorry if it offended you.
PhilG
PhilG
1,582
4,089
leicester
euramobil 810
since birth
you didnt.. not at all.
Jul 29, 2013
9,071
18,565
Salisbury
@PhilG just touch the avatar of whom you need to talk to and a box comes up on is start conversation touch that and you've cracked it
Mr Mousy
620
3,106
Llanelli
Hymer S840
First moho 11/2013, second 11/2014 current from 09/2019.
Phil, I have an spoken to the people at Oyster before and got some great help. Their number is 01858575928. Regards Martin
