OYSTER TROUBLE (1 Viewer)
Mar 21, 2010
2,486
2,993
Hi can anybody help. Have been on to Oyster and still waiting a call back. The Oyster dish will not lower. It shows an error "In It" and also X motor blocked, any ideas. Have checked fuses and connections.
Regards
colyboy
eddie
8,159
41,278
Taunton Somerset
RV
since 1989
which system do you have? And have you checked the roof to ensure everything looks OK uptop?
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
If it is alive as such when the power to the tv is on.... try switching the power off and on and re-try dropping the dish...
I had the same once, and for some reason that was the only way I could get it down..
23,836
72,510
What a pain !
I have had it myself.. In my case a bloody twig had somehow found its way in to the casing and jammed the work gear solid !!
First off try the easy way.. remove the fuse so it all resets
If that does not work then I am afraid it is time to get your climbing gear out as it will have to be taken apart ! :(
colyboy
Mar 21, 2010
2,486
2,993
Eddie thanks for your prompt reply.
The unit is about seven years old, not sure what model it but it is 85cm auto.
Everything is live , the TV is on and working BUT no showing any programmes the sat is not in line with Astra 2. Have taken the fuse in and out several times but still no good.
Error shows "In It" and "Ex Motor blocked" and a red light is flashing
colyboy
23,836
72,510
Yup.. same as I had..
Thought it was gonna be a motor replacement at the very least but like I say,,, sodding lumop of twig got in there somehow.. ( still baffled as to how it happened even now.. )
It is something I will not easily forget as it happened on a site near Yarmouth on a really hot sunny day..
I ended up getting my 'builders bum' sun burned !!!!!!
eddie
8,159
41,278
Taunton Somerset
RV
since 1989
before you go any further you really have to check that there is no physical problem
Eddie
colyboy
Mar 21, 2010
2,486
2,993
Eddie, have been up on the roof can't see any probs!!
colyboy
eddie
8,159
41,278
Taunton Somerset
RV
since 1989
Right then. It will probably be either a limit switch up in the roof mounted unit that needs re-adjusting (bending ;)) or, the PC board needs replacing :eek:
How handy are you?
Eddie
colyboy
Mar 21, 2010
2,486
2,993
Many thanks Eddie. I think it will be a trip to Taunton in the next couple of weeks. Will phone you.
colyboy
