OYSTER TROUBLE
Discussion in 'Motorhome Chat' started by colyboy, Oct 30, 2014.
  1. colyboy
    colyboy Funster
    Mar 21, 2010
    731
    618
    Hi can anybody help. Have been on to Oyster and still waiting a call back. The Oyster dish will not lower. It shows an error "In It" and also X motor blocked, any ideas. Have checked fuses and connections.
    Regards
    colyboy
  2. eddievanbitz
    eddievanbitz Trader - Funster
    Oct 4, 2007
    3,614
    11,298
    Taunton Somerset
    which system do you have? And have you checked the roof to ensure everything looks OK uptop?
  3. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,762
    39,080
    If it is alive as such when the power to the tv is on.... try switching the power off and on and re-try dropping the dish...
    I had the same once, and for some reason that was the only way I could get it down..
  4. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,584
    22,497
    Narrfoook
    What a pain !
    I have had it myself.. In my case a bloody twig had somehow found its way in to the casing and jammed the work gear solid !!
    First off try the easy way.. remove the fuse so it all resets
    If that does not work then I am afraid it is time to get your climbing gear out as it will have to be taken apart ! :(
  5. colyboy
    colyboy Funster
    Mar 21, 2010
    731
    618
    Eddie thanks for your prompt reply.
    The unit is about seven years old, not sure what model it but it is 85cm auto.
    Everything is live , the TV is on and working BUT no showing any programmes the sat is not in line with Astra 2. Have taken the fuse in and out several times but still no good.
    Error shows "In It" and "Ex Motor blocked" and a red light is flashing
    colyboy
  6. Jaws
    Sep 26, 2008
    18,584
    22,497
    Narrfoook
    Yup.. same as I had..
    Thought it was gonna be a motor replacement at the very least but like I say,,, sodding lumop of twig got in there somehow.. ( still baffled as to how it happened even now.. )
    It is something I will not easily forget as it happened on a site near Yarmouth on a really hot sunny day..
    I ended up getting my 'builders bum' sun burned !!!!!!
    • Like Like x 1
  7. eddievanbitz
    Oct 4, 2007
    3,614
    11,298
    Taunton Somerset
    before you go any further you really have to check that there is no physical problem
    Eddie
  8. colyboy
    colyboy Funster
    Mar 21, 2010
    731
    618
    Eddie, have been up on the roof can't see any probs!!
    colyboy
  9. eddievanbitz
    Oct 4, 2007
    3,614
    11,298
    Taunton Somerset
    Right then. It will probably be either a limit switch up in the roof mounted unit that needs re-adjusting (bending ;)) or, the PC board needs replacing :eek:
    How handy are you?
    Eddie
  10. gillnphil
    gillnphil Funster
    Apr 12, 2010
    905
    3,606
    West Suffolk
    I had the same problem on the same dish on my last van. I contacted Conrad Anderson of Birmingham who were more than helpful.
    Phil
  11. colyboy
    colyboy Funster
    Mar 21, 2010
    731
    618
    Many thanks Eddie. I think it will be a trip to Taunton in the next couple of weeks. Will phone you.
    colyboy
    • Like Like x 1
