Outdoor power at home. (1 Viewer)
Jul 2, 2011
953
492
UK
Swift Kon Tiki Tag, 2007.
Newbie
About to get a price for outside lights, nothing to do with our first MH that is hopefully arriving next week.
Is it worth getting a quote for a outside power point too is the question. For what reason would i want to have a power out to the MH. Can use extension lead for occasional use (vacuuming etc), so would it be worth at least getting a price?
Would it be a normal domestic 3 pin plug outside and some sort of adaptor for the EHU lead?
Steve
Apr 18, 2009
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
Well worth it I would say, I have a outside socket and use it all the time not just for the motorhome, just have a proper outdoor socket and get an adapter for your hook up lead:thumb:
scotjimland
2,327
10,077
A Woosh bang
Steve
Only you can say if you would use it or not , certainly very useful of keeping the van's batteries on charge .. and using a heater in the winter..
You could have either a waterproof domestic 13A socket .. which means using an adaptor or a dedicated EHU lead just for home use... that means you can use the socket for any other domestic or gardening appliance .. or a Blue 3 pin 16A outlet same as they fit for on EHU posts .... my preference is a 16A socket ..
Have it done at the same time as the lights and it will be cheaper than having it done later on ..
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Steve
Hi Steve, it is certainly a good idea to have an external power socket. We have one and use it regularly to keep the van hooked-up to maintain charge for batteries and particularly for running the fridge for a day or so before travelling.
Brian
Brian
Encantador
Jul 2, 2011
953
492
UK
Newbie
Thanks, I don`t think I would have much use for it for anything that I couldn`t use a extension lead for, so would only really consider it if there was a good enough reason for the MH, but never having had one before wasn`t sure.
Would you normally leave it connected permanently if you had a outdoor socket?
No harm in getting a price.
(Sorry, this post crossed with the couple above, seems like there are enough reasons to at least get a price)
Steve
icantremember
8,333
17,545
Hymer T-SL668
since 2005
Would you normally[HI] leave it connected permanently [/HI]if you had a outdoor socket?
Not necessarily but it is more convenient than an extension lead
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Steve
Yes.
The electronics and alarm flatten the battery is a very short time these days ( 2, 3 weeks ) so I'd say it is essential.
scotjimland
2,327
10,077
A Woosh bang
Steve
indeed,
just bear in mind when you get a price, as it's an outside socket it should have it's own circuit protected by an RCD .. so will be more expensive than an outside light .. and waterproof sockets are fairly expensive.
Encantador
Jul 2, 2011
953
492
UK
Newbie
Don`t suppose anyone can give me a `ball park` figure?
Where I would probably want it would be behind a gate which would be about 5ft from the outside electricity meter/fuse box, so assume that is where they would take a feed from.
scotjimland
2,327
10,077
A Woosh bang
I'm not in the contracting 'game' so only a rough idea..
Socket £30 ..
RCD £30
+ cable + time
say ... £100 - £125
43,329
49,444
Steve
in a word......Convenience.
i have a dedicated blue Euro-socket fitted to my garage wall (RCD protected) next to the RV.
i also have a compact adaptor, below, so I can use it for normal 3 pin plugs
Encantador
Jul 2, 2011
953
492
UK
Newbie
Thanks, worth doing for that sort of money.
Thanks for the replies.
Steve
Apr 18, 2009
3,569
3,367
Hymer B584, A Class
Not long enough!
Did some of it myself, just got the guys who were rewiring my house to put the wire were I wanted it and wired in the socket myself. I do believe a spur can be taken from almost any ring main although I'm no expert and I'm sure someone will correct me:winky:
This is the one I fitted Link Removed
43,329
49,444
the socket in my pic was around £5 and an RCD, depending on your fuse box make, will be around £20 to £30.
probably 1/2hr to install if its only 2mtrs from fusebox and straightforward.
i would say around £75 'all in' for a 'one man band' electrician.
you will then have power for other outdoor tasks as well....lawnmower, hedge trimming etc
rikfos
315
199
hereford
coachbuilt
outdoor power
I leave my power on all the time.
On frosty nights , I leave the heater on low.
Good for powering fridge up, so you can be away quickly.
Saves having the lead trailing out through the letterbox
scotjimland
2,327
10,077
A Woosh bang
On frosty nights ,[HI] I leave the heater on low.[/HI]
Do you mean the van heating or a stand alone heater ?
Reason I mention, this was discussed on another thread.. if it is a stand alone heater, in the event of a fire your insurance may not (read probably not) pay out .. worth checking ...
wasp
1,724
18,180
Warsop
None gone caravannin
I got an external one and M/H is permanently on hook up it`s handy right now but god knows how much the leccy bill will be:Smile::Smile::Smile::Smile::Smile:
Terry
11,932
9,084
Lincolnshire
Can't remember ;)
Mine is plugged in permanently :thumb:I have 2 outside sockets in the garden but the van is plugged into the garage via it's hook up lead ::bigsmile:
terry
harryoxford2
524
251
Bishops Stortford Herts
B
2010 and camper all my life
Steve
You can pick up the adapter, thats if you dont get one supplied with your motorhome..on ebay.
As far a wiring goes ya have to get a bit techy....if you are techy minded you can save yourself a fortune by doing it yourself. I had a mate who was an electrician and although fully confident in my electrical ability I always used to pay him to check my work and connect the last wire. Pay an electrician to assess the job and tell you what to do and where to do it...thats the labour part of the work done.
Then pay him again for the final check over.
You can pick up armoured outside cable at diy stores or cheaper through ya friendly electrician ...
Just a thought at saving a few bob.
spannermanwigan
392
207
wigan, lancs
coachbuilt
since 1973
Have an external 13 amp 3 pin socket fitted and buy one of these to connect your hook up lead to
[ame]http://www.amazon.co.uk/Hook-Up-Adaptor-Caravan-motorhome/dp/B001AVLPF2[/ame]
if your going to tour europe you also need the 2 pin version as well
once youve had your socket put in you will find it useful for lots of things
you will need to charge your van from time to time also, ours is permanently plugged in when on the drive
regards
Steve
TheBig1
17,630
43,278
There is another far cheaper way of doing it. Buy an external socket kit from B&Q or elsewhere. Aldi had them in a few weeks back for £15 or thereabouts.
The kit comes with the socket and RCD pre wired, so if you can drill a hole and fit a plug its simple
Decide where you want the socket on the outside wall and try to ensure its near a socket on the inside wall.
Drill a hole through the wall near the position but avoiding any wires or pipes. You can get a cheap wire and studwork detector for under £10 and good for many other jobs.
push loose end of wire through hole and fix socket on outside wall
the wire you just pushed through wall, fit the standard 3 pin plug
clip cables for neatness and safety
plug in and switch on
simples
Should take 15 minutes and is an easy DIY task that does not need certifying by an electrician as its not wired into the ring, just a plug in appliance
hawkmoon
20
3
Buckinghamshire
Since 2010
I have the same type fitted, yes easiest option is to locate on an outside wall where there is a double socket internally. Switch power off on ring main, remove double socket, drill thro wall, slide cable thro, position external socket, drill fixing holes and secure. Connect cable to back of internal socket if qualified or get a friendly electrician to do this, repeat for new external socket. Use suitable sealant around cable egress holes & around sides & top of ext socket, test & job done. Only problem I have is opening the d*mm front flap as its very tight. :Smile:
