Our First Winter arriving soon, Help (1 Viewer)
4matt
113
39
East Riding
I'm a newbie in my second year.
We are wondering about the amount of time away we will get while the cold winter weather is here. It could mean we don't get to use our Van for some months. What would those who 'Lay up' their vans recommend as the best way to keep everything in tip top condition throughout those damp winter months while the van sits on the drive not being used.
I am curious to know how many other MH owners don't use their vans over the Winter. We would like think we will but as things stand we haven't really had much chance in the past to get away in the winter while we Caravan'd.
So Over inflate the tyres and give it a run every couple of weeks to the Supermarket. Is that enough to keep it sweet? Anything else?:Blush:
estcres
1,300
767
Sunny Bournemouth
since 2005
If possible, connect to an electric supply (EHU) and keep the batteries charged, you can also put a small electric heater in the vehicle which helps prevent damp.
Make sure you drain all the pipework and water storage tanks and open all taps, shower head etc. Ensure any gas bottles are turned off.
Give the vehicle an occasional run, as you say, every 2 weeks, get the coolant and oils turning, ensure the brakes don't become stuck also the clutch.
I used to give mine a good 30 mile run which got the heat distributed around the vehicle.
Some people remove their cushions and seat covers and store them in the house, we used to do this but recently have left them in the vehicle.
Of course, you could always pack up for the Winter and head South. (Not always practical for some people)
OllieUK
259
300
Ramsgate
Bessacarr E520
Mine will be going into inside storage.
1. Drain all the water from fresh and grey tanks, leave taps open.
2. Remove or turn off the gas cylinders.
3. Lift the upholstery so that fresh air can circulate beneath the seats.
4. Open all lockers, and inside doors so fresh air can circulate.
5. Slightly open a skylight so fresh air can circulate throughout the van.
6. Chock the wheels, remove the handbrake.
7. Remove surpluss bedding etc.
8. Turn off the habitation battery via the control panel or fuse box.
9. Make a list leave in van so you can reverse all of the above when you reuse your van.
10. Check your van periodically ( Me weekly ) take for run when convientent.
If I was going to leave the van for a few months I would also disconnect the main battery.
Nov 18, 2011
11,862
43,121
Planet Earth
A van
Over 25 year's
don't stop using it just drane down and carry sum water in a container and keep using it you got central heating and lodes of places open all year round
time to resurrect the winter camper thread i think::bigsmile:
jools66
59
22
Fulltime Devon/Europe
FT since 04/12
Do your best to get out and use your van all winter ::bigsmile:
It has all you need to be comfy so why not :thumb:
Nov 18, 2011
11,862
43,121
Planet Earth
A van
Over 25 year's
you not far from me i don't think drop by sum time and i will show you wat you nead to use it all year round we never stop using our van drop in to the winter campers thread to keep capering::bigsmile:
Bebe
189
148
Spain/East Yorkshire, Uk
Since 2001
We've had caravans all my life before having motorhomes. We always open locker doors and stand cushions etc up on their sides. We also place bowls of salt everywhere. This takes any moisture out of the air. It works too.
Chris
21,056
279,140
10 years
I think I prefer using the van in the winter months.
It's an expensive item to have laid up for half the year.
Just pick your sites/ locations carefully and enjoy our beautiful country:thumb:
ukbill
5,501
5,274
Pinoso
4 berth low profile
best thing is to use it mine gets lonely unless i tend to her and take her out :ROFLMAO:
4matt
4matt
113
39
East Riding
Thanks to all fast replies. Yes pretty much what you need to do for a caravan lay up. We used to keep the window open slightly but found that since the neighbours got a wood burner we ended up with black soot inside the caravan so stopped that. We used to just leave the heating on low in the caravan via our hook up on the drive. Now though we have a diesel heater so the small electric heater sounds like a good idea. Never use the hand break while at home anyway. Never thought about the clutch binding though. Our cushions are fixed so cannot be lifted only slid out. So maybe do that instead...
We would love to just be able to keep on using it but Winter is tough (time wise) for us so don't get lots of time to get out and about.
Thanks again.
Still curious as to percentage of those who don't use their vans over Winter....
jonandshell
5,476
8,299
Not got one!
Thanks again.
There you go!
Biggest danger - frozen water.
Drain down.
Open all taps.
Blow into all taps to clear pockets of water.
Putting in a heater is not enough, heat does not penetrate to pipes and taps shielded by cupboards.
dreckly
102
57
cornwall
Back on the road after a 4 yr break
Winter camping thread, yes please.
daisy mae
675
597
Leicestershire
C class Coachbuilt
I`m a newbie, now 1 year
Picked my new to me van up today, after a two hour drive I soon got use to it, as it is my everyday vehicle as well , it will get used, I intend to try camping this winter, didn`t last year in the Topaz, I will drain it down, apart from the toilet, will carry water in containers any hot water required will heat up via kettle, no hardship, use to decades ago when tenting. so another adventure starts. :thumb:
A pity and a waste if not used, jmo.
43,357
49,626
dont put a radiant heater in the van......instead use an oil filled radiator stood on a tray....they have been known to leak.
far safer than an exposed electrical element
Nov 18, 2011
11,862
43,121
Planet Earth
A van
Over 25 year's
i use a fan heater on low setting find that works as it circulates the warm air as radiators the heat just goes to the roof and i open all the cupboards wardrobe to allow air to circulate
works for me
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
If you're going to use a room heater you also need to open a vent, perhaps the toilet vent would be most secure. You need somewhere for the warm wet air to go.
4matt
4matt
113
39
East Riding
How would you get flat spots when the vehicle is taken for a run every couple of weeks. over inflating tires and using the motorhome is dangerous. :Eeek:
Sorry I mixed up a couple of things in my OP. If I was to lay up and not use the van then over inflation is a good idea. However, yes If the van is going to get used then the correct pressure is advised always.
As things stand, we will make sure it get a run every couple of weeks if we don't use it more often. :thumb:
