One or Two Warning Triangles for Europe ? (8 Viewers)
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Two - yes and yes plus many other things depending on which country you are in
43,332
49,527
GB sticker.....no, if your number plate has the GB emblem on the left hand side, otherwise yes.
Triangles......only one required for non nationals
Beam deflectors are compulsory unless your beam dips straight up and down....or you get away without them.
Are you going to drive after dark, which may not be until late evening anyway.
MattR
4,105
38,982
Beds
Panel van
Years
It depends on what countries you visit - some require two and I would always have two anyway.
Beam deflectors are required when driving at night - I haven't used them over the last three years as I aim to be onsite before dusk. I do, however, have them available if required. I'm not sure whether I am legally allowed to drive without having them if I am not dazzling other drivers. Many countries do require headlights to be on all of the time so don't risk driving after dusk without them.
GB plates are required unless your number plate has GB on it.
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
Is it one or two triangles for Europe ? - I think the answer is yes, we carry 2 out of habit
Are beam deflectors necessary ? - Waste of money - are your driving at night!!!!
And is the GB sticker mandatory ? - I would have thought so, but I drive a Spanish MH currectly in UK and do not display a ES sticker!!!
Then there is spare bulbs, yellow vest for each passenger, spare glasses if you wear them, the list goes on and on and on..................
Thanks,.
19,738
52,048
uttoxeter
ambulance conversion
50 years
You can get defectors at any motoring place, halfords , fuel stations , ferry , almost anywhere, I put some on , the first time over and never taken them off, passed two mots since.
And there is at least one country, don't know which that requires a gb sticker even if it is on your number plate, but all these things are so little money it's not worth not having them all(y)
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Suggest you refer to the attached document from the AA which show clearly what is required on foreign travel. Like a lot of things some people feel if they have not been stopped in the past it is not required now - rules change every year . It clearly show GB sticker is compulsory unless included in the number plate. It clearly shows deflectors are required regardless of what time of day you drive and for the record I have been checked on the quayside for fitment by the Gendarme. Even in Spain where they do say foreign nationals only need to carry one warning triangle incidents of on the spot fine by local plod have been imposed so they recommend carrying 2
  • compulsory_equipment.pdf
53,484
150,245
2 triangles for Spain other 1, but some counties 2 is advisory only. If traveling through any non EU country (Switzerland) you need a GB sticker regardless of number plate type. France you should have speed stickers on the back if over 3500kg, although the French don't seem to bother.
Charlie
Charlie
3,211
3,639
Herefordshire / Worcestershire borders .
Auto Sleeper Kemerton.
Im a newbie
I played safe and ordered 2 triangles..
Is there any requirement for where the GB sticker has to go ?
I have ordered
2 Triangles
1 X GB sticker
Beam deflectors
2X Hi Vis vests
1 breathalyzer device with 5 tubes
1 full set of spare bulbs
1 First Aid kit
Are there any more requirements for the van ?
Thanks !
MattR
4,105
38,982
Beds
Panel van
Years
I would put the GB sticker on the passenger side of your mh so that it is more obvious to those driving behind you on the continent.
32,667
66,625
If you wear glasses, some countries (Spain) you need to have a spare pair with you, if you are driving......
If you wear glasses regardless of a 'requirement' to have a second pair it makes good sense ... if you break them you'd be totally scuppered with just the one pair!
Charlie
Charlie
3,211
3,639
Im a newbie
I have two pairs in the van. One normal pair and one prescription sunglasses pair. It was on my mind to add another pair from out of my car . I only wear glasses for driving .
Must go right now and make a note !
Thanks for the reminder !
19,738
52,048
uttoxeter
50 years
Charlie, don't keep worrying about stuff, just go and enjoy, you will be surprised how simple it all is and if you haven't got something , they sell them in France as well, from all the posts , I think you have more than got it covered(y)(y):)
Charlie
Charlie
3,211
3,639
Im a newbie
I know mate... It's just me being pedantic but the glasses reminder is golden as although I had briefly thought about it I would very likely have forgot them.
I have made a note in my study to make sure I put a spare pair in the van..
19,738
52,048
uttoxeter
50 years
Must admit you've got me on this one, only use reading glasses and only pound land ones at that but usually take about 6 pairs:doh::RollEyes:
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
I have a gb sticker and beam deflectors. They've been in the glove box of the car, then I moved them to the transit glove box and now they are in the Renault glove box.. no doubt one day I will remember to put them on some vehicle or other..
Charlie
Charlie
3,211
3,639
Im a newbie
Mmmmm . I wear glasses only for distance. Driving without them is not only uncomfortable but if I was involved in an RTC I would maybe fail the vision test.. Don't want to end up in a Bastille. See what I did there ? French that is
Charlie
Charlie
3,211
3,639
Im a newbie
Yeh but don't come moaning when Johny Darm locks you up....
