DBK
We use our diesel heater when necessary. You get used to the noise, such as it is. Check your heater has silencers on both air inlet and exhaust.What do others do when camping off-grid (no EHU) in weather conditions where it rarely gets above 0 degrees (like now) and need to use the heating system? If I don't use the frost stat protection feature the water could potentially freeze overnight or even during the day. If I use the frost stat, the diesel heater will fire up when needed to heat the water. Problem with this is that the heating system is under one of the lounge sofa's, which makes up half the bed, so I'm pretty sure the noise from the heater's exhaust and the constant trickling of water would keep me awake most of the night.
Do most of you use gas-fired heating systems, or just not bother going away in cold / freezing weather?
