RogerThat
Soooo.....
You may remember last month when I started the engine with the EHU plugged in http://www.motorhomefun.co.uk/forum/threads/so-i-started-the-engine-with-the-ehu-plugged-in.140456/
Well, today I flipped the switch on the control panel to 'cab' and nothing happened. No lights, no 12v sockets, no volts showing on the little meter in the control panel, no nothing
Flipping the switch to 'hab' and everything springs in to life
My first thought was that little glass fuse in the EHU charger again, but that's checked out ok
If I plug the EHU cable in, everything works, all the lights and 12v sockets etc, BUT the vehicle battery is NOT receiving a charge (the hab battery DOES receive a charge when the switch on the control panel is in the hab position). So I know the charger itself is ok.
I've not started the van for a couple of weeks, so it's definitely not the 'human error' I made last time and the cab battery is actually charged, showing 12.6v on a multimeter.
I've checked every single fuse in the glove box, I've checked the four fuses under the wardrobe cupboard (where the EHU charger is), everything seems ok.
Where should I begin in trying to work out why I've no power when switched to 'cab'?!
Is there a big "MOHO" fuse in the engine bay perhaps? I'm suspecting there is as there are no volts coming in to the control panel and no charge going back out to the battery.
Can't get to the bonnet at the moment as I'm parked right up against the fence. Will roll it back tomorrow and have a poke around under the bonnet.
It's a 1999 Swift Sundance on a Ducato.
