No hot water when running on gas - help!! (1 Viewer)
Liftdoctor
LEEDS, West Yorkshire
Autosleeper Inca
newbie
Newbie here [just bought first MH last week!] - Truma Ultrastore heats water when on EHU but fired up the heater on gas today & after 15 minutes still had no hot water out of tap - any ideas would be greatly appreciated. Many thanks
Langtoftlad
8,865
151,382
Langtoft, South Lincs
WildAx Aurora FB [PVC]
Had a similar problem a few weeks ago - a weak red light was illuminated... Manual suggested might be a glitch in the gas supply.
Recommendation was to turn off the boiler for 10 minutes & turn it back on again.
Worked for me
Try it.
lorger
9,668
90,696
Dumfries
Knaus Sun 650MEG
A few daft questions first,
You do have gas
Gas is switched on
Does the water flow ok when opening the hot tap.
Is it blow air heating using the boiler or do you have a boiler for water and heater/fire
Does it have a control panel, if so any codes or flashing lights red, Amber or green are the normal
Liftdoctor
Liftdoctor
Autosleeper Inca
newbie
Gas on, vent cover off, control knob to 'flame' icon, heater ignited & giving off both convection & blown air heat. Cannot see any light on the control panel. I do get hot water when I run on the electric hook-up, but not on gas. Water flows very well, but very cold! Enword - cheers for the video - it confirmed my correct operation of the controls. Thank you everyone, for your speedy assistance to rectify my problem - I suppose I'll wash in cold for the time being!
lorger
9,668
90,696
Dumfries
Knaus Sun 650MEG
I'm not sure if yours is the same, if you look at the video the dial on the right normally goes Amber on mine while the water is heating up. If any fault appears it will go red, is your going Amber or any colour. When you put your blow air heating on while on gas you should hear a fan then the boiler firing up, you should also hear this for the water.
Is the boiler accessible as it might have blown a fuse.
Liftdoctor
Liftdoctor
Autosleeper Inca
newbie
Thank you, everyone, for your assistance - the MH is lovely & warm now with lots of hot water for a shower, etc.
The problem we were having was the sequence of the process for the provision of heating & hot water!
Ta muchly.
