No hot water when running on gas - help!!
Discussion in 'The Beginner' started by Liftdoctor, Oct 13, 2016.
  1. Liftdoctor
    Liftdoctor Read Only Funster
    Oct 13, 2016
    3
    LEEDS, West Yorkshire
    Newbie here [just bought first MH last week!] - Truma Ultrastore heats water when on EHU but fired up the heater on gas today & after 15 minutes still had no hot water out of tap - any ideas would be greatly appreciated. Many thanks
  2. Enword
    Enword Funster
    May 20, 2014
    867
    2,871
    Devon
    Did you take off the outside cover?
  3. RowleyBirkinQC
    RowleyBirkinQC Funster
    Sep 20, 2014
    800
    1,885
    Dazed & Confused
    Did you fire up the gas heater or the boiler? What colour light is on the control?
    • Like it Like it x 1
  4. Enword
    Enword Funster
    May 20, 2014
    867
    2,871
    Devon
  5. Langtoftlad
    Langtoftlad Funster Life Member
    Apr 12, 2011
    2,052
    5,169
    Langtoft, South Lincs
    Had a similar problem a few weeks ago - a weak red light was illuminated... Manual suggested might be a glitch in the gas supply.
    Recommendation was to turn off the boiler for 10 minutes & turn it back on again.
    Worked for me
    Try it.
  6. lorger
    lorger Funster
    Jul 11, 2008
    6,407
    7,856
    Dumfries
    A few daft questions first,
    You do have gas
    Gas is switched on
    Does the water flow ok when opening the hot tap.
    Is it blow air heating using the boiler or do you have a boiler for water and heater/fire
    Does it have a control panel, if so any codes or flashing lights red, Amber or green are the normal
  7. Liftdoctor
    Oct 13, 2016
    3
    Gas on, vent cover off, control knob to 'flame' icon, heater ignited & giving off both convection & blown air heat. Cannot see any light on the control panel. I do get hot water when I run on the electric hook-up, but not on gas. Water flows very well, but very cold! Enword - cheers for the video - it confirmed my correct operation of the controls. Thank you everyone, for your speedy assistance to rectify my problem - I suppose I'll wash in cold for the time being!
    • Informative Informative x 1
  8. lorger
    lorger Funster
    Jul 11, 2008
    6,407
    7,856
    Dumfries
    I'm not sure if yours is the same, if you look at the video the dial on the right normally goes Amber on mine while the water is heating up. If any fault appears it will go red, is your going Amber or any colour. When you put your blow air heating on while on gas you should hear a fan then the boiler firing up, you should also hear this for the water.
    Is the boiler accessible as it might have blown a fuse.
  9. Liftdoctor
    Oct 13, 2016
    3
    Thank you, everyone, for your assistance - the MH is lovely & warm now with lots of hot water for a shower, etc.
    The problem we were having was the sequence of the process for the provision of heating & hot water!
    Ta muchly.
    • Thanks Thanks x 1
