no 12volts (1 Viewer)
bmb1uk
253
144
LEICS
coachbuilt
Hi all I have a bessacarr e450,but have problem with 12v, no power to toilet button ,or cooker ignition, and no power to the 2 12v sockets, have checked fuses in wardrobe, and 1 near battery but no luck, any assistance would be very helpful. regards BAZ.
a meery christmas to you all
43,331
49,467
may be worth changing the fuses.
i recently had a problem and all the fuses looked fine but a continuity test showed one to be blown even though it looked fine.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
may seem like a dumb ass answer but i presume you have checked that the battery has power in it:Doh:
andy
Jan 5, 2009
72
31
Chillington Devon
Low profile
since 2006
hi
I have an E560 with simalar problems in so far as all 12v goes of when the alarm is set.
Premier motors in Chichester spoke to Bessacarr who said it was a known problem with the control panel above the door.
Needs repair and new software, but no spares as original company has gone out of business, we are told need to leave van with dealers for 3 weeks to have panel sent of for work and then returned.
Awaiting agreement to a more reasonable timescale!!!!!
Hope this helps
Peter
bmb1uk
bmb1uk
253
144
LEICS
coachbuilt
Hi, will change fuses, yes the battery is good, have not lost all 12v functions, still have lights, water pump working, steps working. regards BAZ
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Just as a quick check, pop your cassette out and have a look just above. There should be the wiring for your loo. It may be possible that the circuit has been broken by a lead loose/knocked off when attending toilet cassette.
It may not be the cause (depending on how it is wired) but may be worth checking.
bmb1uk
bmb1uk
253
144
LEICS
coachbuilt
Hi pappajohn, well done mate you were spot on,many thanks to you and all who replied BAZ. :thumb:
