No 12v
Discussion in 'Tech/Mech General' started by Darren, Nov 4, 2015.
  1. Darren
    Darren Funster
    May 27, 2014
    106
    18
    Canterbury Kent
    I have an electroblok 225 which is then connect to a let 500 control panel above the door. I have been in the van this afternoon but none of the 12v lights water pump fridge work. I have checked the fuses on the electroblok which seem OK the battery is fully charged and the panel lights up when you press the 12v rocker switch on. Is there a reset button on the electroblok? Or anyone have a thought on what's gone wrong?
  2. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,080
    1,212
    Dronfield - Derbyshire
    Have you checked whether there is any power to the unit. There is probably a large fuse in the power lead from the battery.
    See also ---------------http://karavaanarit-fi-bin.directo.fi/@Bin/57b95e89daa46b3fd2548a55beff7134/1446660676/application/pdf/114467157/Schaudt_Electroblock_EBL99_G_Ingles.pdf
  3. Darren
    Darren Funster
    May 27, 2014
    106
    18
    Canterbury Kent
    Thank you for trying to help. I have power to the control panel and it shows my battery fully charged . The green 12v is lit and when I press the rocker switch for the water pump it also illuminates but does not run.
  4. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,080
    1,212
    Can you check the voltage is at 12+ V with a multi meter?
  5. Darren
    Darren Funster
    May 27, 2014
    106
    18
    Canterbury Kent
    With the power lead plunged into the electroblok it reads 14.2 so I presume the charger is working.
  6. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,864
    1,915
    Warwickshire
    Are you sure that the battery isolation function has not been activated at the control panel. I realise that it sounds as if all is switched on, but as well as the 12V on/off switch, there is an option to isolate the habitation battery (e.g. when changing it). Here is a clipping from the trouble-shooting guide in the manual for the EBL226 (slightly later than yours) - note the second point. Afraid I have no direct experience of the control panel fitted in your Hymer (mine has a much older EBL/Control panel). I think a detailed reading of the manuals for both your EBL and control panel might be helpful if you have not already done so.
    p.s. sorry just realised the clipping does not make sense without the column headings. First column is 'Fault', middle column is 'Possible Cause' and third column is 'Remedy'
  7. Darren
    Darren Funster
    May 27, 2014
    106
    18
    Canterbury Kent
    Thanks jealuc will try to find out about the battery isolator.
  8. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,864
    1,915
    Warwickshire
    If you do not have the relevant manuals for EBL and control panel, they can be downloaded from the Schaudt website. Post if you need help with this.
  9. swidy
    swidy Funster
    Apr 3, 2011
    157
    323
    wakefield
    Hi Darren
    I had a problem with 12v all appeared ok until I demanded power, after checking voltage on just about every place u can, I then checked voltage with demand on and off, in the end I checked the output on the control box which showed 13v until I turned something on it immediately dropped to zero volts it turned out to be a corroded wire under the van which was still connected enough to show volts travelling along the wire but as soon as I demanded power it could handle it, it took me weeks to find it and 10 mins to repair. it may be something totally different, but I'm just saying when you check readings get someone to turn something on and off to see if the readings change. Hope this help or al least makes sense lol
  10. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,080
    1,212
  11. Darren
    Darren Funster
    May 27, 2014
    106
    18
    Canterbury Kent
    I have no manuals for thi s equipment as of yet
  12. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,080
    1,212
  13. maxi77
    maxi77 Funster
    Mar 20, 2013
    305
    169
    Kingdom of Fife
    As well as the battery test switch most panels have a 12v on/off switch. An interesting fault I have found is a partly blown fuse which allows you to see voltage but fails to carry any current. One thing to check is with the pump selected and the pump light on try switching something else on does the pump light stay lit or go out?
  14. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,472
    884
    South Glos
    The activation that @JeanLuc is talking about is in the lt500 manual. Hold the 12v main switch for more than 5secs the lights on the panel will flash and the battery will be connected. I had the same problem when I changed batteries without reading the manual
    Found a copy of the manual here http://caravaning.si/caravaning/file/LT_500.pdf
  15. Darren
    Darren Funster
    May 27, 2014
    106
    18
    Canterbury Kent
    Well had it confirmed today that the 12v relay in the Ebl is defunc.
    • Like Like x 1
