New Tyres (1 Viewer)
Dec 18, 2010
885
929
Norfolk.
Autotrail cheyenne
2008-20??
We changed our tyres about 20,000 miles ago (aprox 2 years) got what we thought were the best Michelin Agilis Camping,the rear are fine but the front have worn down and need replacing.Thought I would go for Hancook all season witch are about £30 each cheaper.any thoughts? and any ideas who are cheapest online as my tame mech
anic will fit.BTW van is 2004 Ducato tyres are 215/70 R15.
Thank's Martin
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
I've heard that the Hancock are very good. Thought your current tyres should have lasted longer.
Are they the right load rating?
Is your tracking OK?
Mr Ed
Dec 18, 2010
885
929
Norfolk.
Autotrail cheyenne
2008-20??
Yes Sue we thought the same,tracking fine (been checked) not sure what you mean about load rating?
Lenny HB
52,377
146,657
On the coast in West Sussex
Hymer B678 DL
I have Hankook RA10 all season tyres on my van they have been on for 10,000 miles, just checked the thread depth front 8mm rear 10mm.
Mr Ed
Dec 18, 2010
885
929
Norfolk.
Autotrail cheyenne
2008-20??
So your fronts are wearing quicker than backs.Seem strange to me as most of the weight is in the back by a large margin.
Sep 22, 2013
199
197
Halifax
Relay self-build
Trainee MH owner
No, front wheel drive vehicles tend to wear the front tyres quicker. Plus if you brake heavily, the weight is thrown forward onto the front tyres and I suspect these characteristics have more effect on the wear rate than the static loading.
Peter A Forbes
270
184
Rushden, Northants, UK
Mercedes 614D
Load rating does define the carrying capacity of the tyre, and very often you can go up a size and load rating and get enhanced life.
We went up from 215 to 225 on the Mercedes, 118 load rating on the front two and 121 on the rear four.
Yokohama rear and Conti Vanco on the front.
See if a 225/70R15 is available and what load rating you can go up to.
Camskill have always done us right on supply-only for tyres.
Peter
Aug 29, 2010
839
1,229
Nuneaton. Only when I have to.
Hymer Exsis t564
Since Sept 2010
We uprated to 225/70R15 112 as part of an SVTech weight upgrade. The Agilis Campings do about 24,000 on the front but do replace them before they get down to absolute legal minimum. Word of caution, the size upgrade does cause issues on the rear when it comes to changing a wheel. That extra bit of width makes clearing the skirt on the rear a bit of a bugger. Event Tyres have always done a good deal for me and fit on your drive.
Lenny HB
52,377
146,657
Hymer B678 DL
Normal on front wheel drive, last motorhome was the same as with last 8 front wheel drive cars.
Jaws
23,814
71,772
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I have raved about Hankook tyres for a few years @Mr Ed :)
SOOO much quieter, SOOO much better grip !!
Sep 4, 2011
2,664
6,754
No more
I had four Hankook tyres supplied and fitted on Monday by the AA for £421. Size 225/70 R16 C
Not driven on them yet, don't want to get them dirty :ROFLMAO:
Rob(y)
Mr Ed
Dec 18, 2010
885
929
Norfolk.
Autotrail cheyenne
2008-20??
Well I'v ordered Hankook optimo £79.50 each quite a saving on Michelin will see if there as good as John say's time will tell.Thank's for your responses.
(y)
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
HanKook are great tyres. My work Ducato (2.0 litre SWB) used to have Good Year Cargo tyres and they were utter shite for grip, even dew on level grass could cause wheelspin at tickover, I kid you not! Changed them last year for Hankook RA08s all round and its transformed the ride, noise and grip. Just last weekend I used it to move the car trailer at Loton Park Hillclimb from rough ground to a spot where I could load the car and they were superb, the only thing that caused wheelspin was when the handbrake locked on the trailer during a reversing uphill manouvre, trying to drag it back down the hill and it wouldn't have it but I did have to give it really big licks on the loud pedal to break traction and that was on long grass, just proves the trailer brakes are ok I suppose.
D.
SMB
Apr 26, 2013
1,229
1,347
Spain
Coachbuild
Fulltiming since February 2013
My front tyres wear a lot quicker with my front-wheel drive van even though there is a lot more weight at the rear, so I had them changed around a few months ago. Also, after advice on MHF, I emailed Continental who sent me the optimum tyre pressures for the size of my tyre and weight on the front and rear axles. Don't know if that has helped but it was better than the bog-standard Fiat recommendation of 5.5 bar front and back
Mr Ed
Dec 18, 2010
885
929
Norfolk.
Autotrail cheyenne
2008-20??
WHAT PRESSURE ARE YOU USING ON FRONTS JOHN (sorry to shout but left the cap lock on)?Don't think 80psi would be right for and I have a feeling it might be a case of trial and error.Martin
Allanm
5,431
9,191
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
We had Continental Vanco Camper tyres all round on our Autosleeper. 22000 miles later we still had 5-6 mm tread on the fronts. Pressure was 5bars front 5.5 rear. The rears had hardly worn at all.
Tyre wear can vary considerable between different drivers, the more aggressive you are on the pedals, the more your tyres wear.
Lot lover
1,291
1,617
Lot, France
Le Voyageur Integral
New boy
Front tyres always wear out more quickly whether RWD or FWD, 80% (?) of the braking is done at the front and the fronts twist this way and that whereas the rears go in more or less straight lines all the time. Plus of course under severe braking all the weight is thrown forward.
This was true with my 1960s VW Beetle where most of the weight is at the back or at least that's how it seemed on wet roads.
Billggski
114
63
Stone
Overcab
Newbie
I always use campervan tyres, 225/75/15 were £102 fitted with high pressure valves. (Which are necessary but few tyre fitters stock them)
It is a controversial point, but why save less than a tankful of diesel to fit white van tyres when proper tyres for motorhomes are available?
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
I think the answer is .... because they are not essential.
We have vanco fourseasons 2 ... they're great for us ad provide a good level of grip in adverse conditions. They are the correct load rating, correct pressures as reccomended by conti ...
I also don't believe they were cheaper than camper tyres ...
So... why use camper tyres ?
Also are high pressure valves required when there is no unusually high pressures?
Standard oem valves should be fine surely?
JockandRita
11,385
147,801
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
What's the difference between your Camper tyres, and my 10x ply 116 (1250kgs) load rated commercial tyres?
If our MH was to spend several months of the year sat in storage, I might consider the (so called) benefits of Camper tyres.
Cheers,
Jock. :)
Flamenca
1,266
804
Europe
Hymer 564
Since 2010
When I change tyres I always have the rear tyres swapped to the front and fit the new tyres on the back. I was told to do this a long time ago by a tyre fitter.
I always do the opposite. I have the new tyres put on the front.
Lot lover
1,291
1,617
Lot, France
New boy
Interesting, I was always told to have the best tyres on the front.
Brian and Jo
3,002
6,447
oswestry,shropshire
A-Class N+B Arto 88F
Been motorhoming for 15yrs.had an American RV for 7yrs,Now got a Niesmann Bischoff Arto 88F
Wrong. new tyres should always go on the rear.
  • mich tyre.pdf
Jaws
23,814
71,772
Thetford Norfolk
C class, Chieftain
I used 72 in the fronts.. 2.8 boxer chassis
Why ? Perhaps on a rear wheel drive vehicle yes.. Certainly not on my tag thats for sure
And having just read that crap from Michelin I will continue to do as I have done all my life.
I sometimes despair at the rubbish that company puts out as being correct.
Brian and Jo
3,002
6,447
oswestry,shropshire
Fine ,what do i know
Doctor Dave
463
1,110
Wiltshire
None
7 years followed by a break of 11 years and then 4+ years but given up now
When I have replaced 2 out of 4 tyres the new ones have always gone onto the driving wheels.
Dave
Geo
Trader - Funster
Jul 29, 2007
11,757
14,563
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
[QUOTE="JockandRita, post: 1948254, member: 49"]What's the difference between your Camper tyres, and my 10x ply 116 (1250kgs) load rated commercial tyres?
Cheers,
Jock. :)[/QUOTE]
About £40 Jock:doh::laughing:
JockandRita
11,385
147,801
Lincs/Cambs border
N+B Flair 8000i
Cheers,
Jock. :)
About £40 Jock:doh::laughing:[/QUOTE]
I knew that Geo, but I was hoping for an answer with a bit of technical content. :rofl:
Cheers,
Jock. :)
