- Jul 14, 2019
- 274
- 189
- Rapido 7086f
Plus 10% for inverter inefficency.1800w/12.5v=144amps required
Ninja 2470w/12.5v= 198amps required.
How are you going to get the power you take out of the batteries back in.
Just don't do it stationary only while driving unless you like bit repair bills.Run the engine with the B2B charger or is this not possible
Which Tower twin air fryer have you gotI have a Tower twin air fryer and it stands beside my smart meter display. I assume because of its small oven size and good insulation, it very quickly switches off the thermostat, therefore using full power only intermittently.
I am surprised at just how little time it is drawing power.
Geoff
Yes we also have one but not tried it yetI know it’s totally different but we often use our slow cooker off grid through the inverter. Brilliant for a bungitallin then going out for the day. Only about 160 watts.
Phil upmeplate
Modern diesels never get up to operating temperature idling from cold, DPF CAT clog up can get glazing the bores, EGR problems.Apart from been inconsiderate to other motorhome people I don't think doing this stationary is on But for a matter of interest What would happen if anyone did run engine while stationary
Allowing for inverter inefficency your 1800 watt air fryer will draw approx 160 amps on full power.Morning LennyHB Just had a reply back from Renogy technical Department and they say for 2x100w Lithium Batteries wired in parallel it's recommended 150amp maximum continues discharge do you or anyone else think that still a no go
That's going to kill your batteries you shouldn't discharge leads at more than the C5 rate if you want them to last. For 2 x 90 that would be 36 amps with that load you are drawing approx 90 amps.Just for info..
You can get smaller wattage air fryers for the odd use.
We have one that's 1000w and runs off an 1100w inverter and 2x 90amp lead acid batteries.
Mainly use it when the grandson comes with us so he can have his fries and nuggets.
Why?changing cooker in our motorhome for an 1800w Air fryer
Why not, we decided not to have an oven in the new van and will use an air fryer.Why?
Are you talking about just the oven?
A traditional cooker is much more versatile.
An Air Fryer is portable so can be brought out when needed
I see the logic in that, but if you already have an oven...Why not, we decided not to have an oven in the new van and will use an air fryer.
I agree if you already have an oven.I see the logic in that, but if you already have an oven...
Plus you're a magician electrickerywise and will ensure you have plenty of power
Yes just the oven The one in our van is a complete wast of time and space and was looking for a different way of cooking The Duchess as now said we will buy an Air Fryer and use it when we are on electric hook up and try and fine something to replace the oven when we are off grid As anyone got any suggestions??Why?
