Motorhome problem! (1 Viewer)
Darren fletcher
3
7
Manchester
Swift
Sorry if this is the wrong forum!
I'm desperate for help and I'm a complete novice. I tried to start my Swift Royale 6 berth 1996 Motorhome yesterday and it turned over very slow. As not to drain the battery I took the key out and the engine still carried on trying to start for a couple of turns then went flat. Now there is no lights on the dash when I turn the key? I tried to use some jump leads but nothing happens? Any advice or help would be great?
treetops1
1,599
1,759
yorkshire/ lincolnshire.
Sold last van-
a long time,since 1996
First job i recon is give your battery a good over night charge then try again tomorrow ,it may just be a Knackered battery.
DanielFord
3,020
3,086
Yup, what he said. Modern jump leads are really tricky to get a good contact on the Ducato jump start points, so I don't think that is indicative. Charge the battery, and try again.
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
And here's a ditto (or is that a ditto ditto?)
Reactions: DBK
Nov 25, 2013
1,119
1,761
kent
Swift Kontiki 669
Since April 2013
New Battery if you want it to start next time.
ianandkath
897
1,519
spain/uk
a class
2 years
sounds like your starter contacts "stuck", or welded together. that can happen with a low battery.
like others have said , take off and charge overnight, becareful when you refit it , that the starter doesn't run. just tap the earth lead on the battery to check
Feb 16, 2013
19,735
52,035
uttoxeter
ambulance conversion
50 years
But what's all this about still trying to start with the key out(n) sounds as if something is shorting somewhere.
Edit sorry overlapped the last post
D
Darren fletcher
3
7
Manchester
Swift
Thanks all for your advice I will charge and try again. The battery and starter motor is only 6 months old.
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
solenoid stuck on the starter, give it a belt, the round thing on the top, not hitting it on any plastic bits, and check the live lead on the back is nt in contact with the other littler leads.
Carol
14,051
112,114
North Wales.
Good to hear you got your problem sorted.
Hi Darren, welcome to the wonderful world of Motorhomes, now that you have found the forum and invested in your Motorhome I would seriously think of joining £15 per a year , you will have access to so much information and have fellow Motorhomers at your fingertips. :welcomesign:
