moisture meter. Which one?? (1 Viewer)
finby
217
norfolk
coachbuilt
about 8
I want to buy a moisture meter for my MH. However selecting one appropriate for the purpose is a bit of a minefield. (I want to be able to check for damp whenever I want, and not have to rely on a yearly hab check). I know that prices start very low (£10 - is this type "mickey mouse"?) and go up to almost anything you want to pay (several hundred).
I also know that Protimeter make a non intrusive (no pin holes left behind) meter for about £200, but their Protimeter mini (the one with probes) costs about £119 ex vat.
What Im trying to establish is:
Whats the most reliable meter to get, and how much should I be spending on one.
Invasive versus non invasive type - any ideas
Any further info I should know.
Any help/info would be gratefully recieved
Martin
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Camping Caravaning now 5'ering 49 years
I think I paid about £20 for mine - pretty basic in so far a it using moisture to form a conductor between two points and although they come to a point - you do not need to actually puncture the surface - only hold it firmly with the two probes in place. indication is by noise and you soon get a good idea of what it is reading when the sound level and volume increase - check it against say wet paper, damp paper and dry paper and you can soon get the hang of it - I dont think it is important to know what percentage of moisture you have only that you have it and would rather not have it :thumb:
Aug 1, 2007
1,288
275
Billingham
since 2003
I think there is too much worrying about moisture in new morothomes, if you are worried consider spending the money on a dehumidifier.
scotjimland
2,335
10,104
A Woosh bang
Sorry Ralph , but I disagree ,
Unless it's damp from sources within the van..ie , bodies, cooking etc. otherwise it must be coming from somewhere.. better to find the cause than treat the symptoms ..
To answer the OP's question.. cheap and cheerful is all you need to detect damp..
jim
S
stagman
Trouble with a dehumidifier is it will pull in moisture from the outside unless , unless everything is sealed .The other problem is , if it is completely air tight the dehumidifier will draw moisture from wherever it can until everything is absolutely bone dry , and what happens then is things start to crack timber etc.
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
I got one in Aldi in the "cheapie" bin for half price about £8 if my memory works better than usual. BTW the % of moisture is relevant, again from memory anything below 20% can be ignored above that needs to be investigated. :Smile:
geoff1947
988
98
Plymouth
low profile
10 yrs
FINBY (and me too) would like the MAKE of a damp meter and where to get one:Doh:
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Hi this is the one that I got from Aldi. Seems well made and works OK. There is some info about it in the link.
HomeNetProducts.co.uk - Admin
Can't help on where to get one try the web site. :Smile:
M&L
75
North Lincolnshire
If you are serious about finding any damp in your van then you need to pay at least £200 for the right one. The cheaper ones will only find it when the percentage of damp is extremely high and by then it will be too late just to reseal any joints.
A few years ago I part exchanged a Caravan for a motorhome and I tested the van before I took it to the dealers and there were no signs of any damp. They tested it in my presence and the machine went balistic with the result that £1000 was knocked of the previously agreed part exchange price.
Mike
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Mike
Mine does that if you press the test button at the same time as you do a test - worried the life out of the missus until I explained
scotjimland
2,335
10,104
A Woosh bang
Mike
Up to 20% is regarded as perfectly normal as virtually all materials have some water content. A cheap meter will detect this no problem ..
I'm not suggesting you were 'done' but some unscrupulous dealers will use readings of 10-15% to knock down the price allowed.
In reality this is fraud so complain to your local trading standards office if this happens.
M&L
75
North Lincolnshire
I can assure you that I was not done as I also used the meter myself, anyway if you believe that a cheap meter will do the job, which it will not, then carry on.
