Mini Heki Fly Screen has gone all saggy. (3 Viewers)
Oct 15, 2011
4,171
11,315
Not Glasgow
Carthago chic eline
Since 2011
Is there any way of rejuvenating my saggy fly screen ? :unsure: I think this was how the mozzies were getting into the van earlier in the year in Portugal.(n)
GJH
29,450
38,827
None, now sold
2006 to 2022
Depends what you mean by saggy I suppose.
If it isn't retracting properly you may be able to fix it by removing the screen and its roller and re-tensioning it (may require removal of the inner frame depending on model).
GJH
29,450
38,827
None, now sold
2006 to 2022
Ah, terminology strikes again. The pleated bit is the blind, the fly screen is the black part of a roller :)
If the blind is saggy because the fabric has lost its stiffness I would guess (only guess though) you have to mend it with a new 'un.
Looking at the Exploded Diagrams/Technical Questions on the page referenced it appears they are part of the inner frame rather than available separately.
Hopefully somebody will come up with a less expensive solution.
TJBi
169
80
West Midlands
Since 2014
Actually, both the blind and the fly screen are pleated. There is no roller. Is the issue with the fly screen material itself or is it a case of the plastic "leader" incorporating the finger pull no longer functioning correctly?
GJH
29,450
38,827
None, now sold
2006 to 2022
Thanks for that clarification. We have a Heki 3 on our current van and the fly screen mesh is on a sprung roller. I think it was the same on the Heki 2 on our previous van so I assumed (obviously wrongly) that the same applied to the Mini Heki.
17,635
43,369
Sadly its down to poor design and when the fabric has gone limp, the only remedy is to replace the lower frame complete. i imagine if you had infinite patience then you could re-fold it and use spray starch or lacquer to harden it again
Feb 9, 2008
4,094
5,915
SW Scotland
LP Coachbuilt
I took mine apart a few months ago to wash and clean it. It was choked with dust. Sadly, since washing it the mesh has started to sag, I guess I'll need a new one.
Jan 3, 2008
3,341
5,359
Pakefield, Lowestoft, Suffolk, UK
Looking
Mine is the same, saggy. When I get home from this trip I am going to remove it and was it. I think it might be costed with something to provide stiffness so I am going to try spray starch then fold it and carefully iron it under a tea towel. If that doesn't work I am going to write to Heki pointing out a poor design and using for a new one gratis. Nothing to loose.
TJBi
169
80
West Midlands
Since 2014
My 7-year-old fly screen is fine, but one of the small lugs on the plastic slider for the blind has broken off, resulting in the blind and slider failing to stay in place and resting at an angle across the frame. Of course, you can't buy the slider, only the entire inner frame. I'm currently debating whether to attempt a Heath Robinson job on the slider (I've read somewhere that wire can be used) or bite the bullet and buy a complete inner frame - which would at least give me spares for most parts for the future!
bigtree
Oct 15, 2011
4,171
11,315
Not Glasgow
Carthago chic eline
Since 2011
I had to buy one as the guides for the cords are very flimsy and one broke off plus the sun probably makes it brittle,should have bought 2 as they take weeks for delivery.
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
+1 try spray starch
11,956
16,570
Interesting this. I have two on my van: one came with the van and I fitted the second earlier this year. The newest of the two was affected by wind that caused the flysheet to bulge downwards out of the frame. As this had never happened with the older one I thought I'd take the both off to compare (and to fix the newer one). On the old one the zig-zag fabric was punched so that a stiff wire guide rail at each side kept it in line and the folds straight. The newer one wasn't punched and didn't have the guide wires but the plastic frame still had the slots that the wires could be fitted to. It looks like the later versions have been made more cheaply by leaving out the wires. I suspect yours is (like my new one) one without the wires.
