Mini Heki fitting? (1 Viewer)
mulaz
97
Durham
3 years
Have a new mini heki to replace my boring skylight. The box includes a small packet of stainless U shaped clips 10mm square? but cannot find any reference in the multilingual instructions.
anyone shed any roof- light on these clips:ROFLMAO:
haganap
12,765
26,476
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Hi mulaz,
I fitted two heiki lights in to my old van and they made a great improvement. I cant remember the clips you speak of? but if I didn't htink they were needed they probably ended up on te garage floor.:Doh:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Are they speed clips for self tappers (they have holes in them) and usualy slip onto plastic parts lining up the holes in the plastic with the holes in the clips, so as to give self tapper a firm hold and avoid splitting a plastic hole
Geo
mulaz
mulaz
97
Durham
3 years
clips
Thanks but No i even double checked
The only thing i can think of is to connect the 2 blinds fitted on the mini heki together.
The clips have sharks edges so doing this would also stop them being removed??????????????????:Sad:
zaskar
1,159
371
5th Wheel
If its what I'm thinging of, they clip onto the inner frame (inside the van) and are used to hold on the outer trim surround. Surprised there's only a couple of them but then mine are beggers for falling off. Have a look at the bottom edge of the inner frame and see if there's more there.
:thumb:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Ah! me thinks i know what they are Imagine you have a fabric head lining and are cutting a new hole for the Heki Might they be used to secure the headling to the inner frame whilst the finish plate is installed, new instalation only parts:thumb:
Geo
mulaz
mulaz
97
Durham
3 years
Fully fitted
Fully fitted in less than 1 hour and i didn't need then *%&*"! clips
what a big difference
recommended to all:Cool:
mulaz
mulaz
97
Durham
3 years
sealent advice
Rang caravan clinic Gateshead /Newcastle Based repair specialist to buy some sealant.
He advised using sealant on a roll and said come down and i will give you some for free!!
so anyone wanting good friendly advice Also recommended repair work give them a try:thumb:
johna
16
HI, The clips are to fix the inner blind to the main frame,once you have fitted your skylight, simply push them onto your main frame at regular intervals, and carefully line up your inner blind frame work with them and push into place. No problem, just replaced my 2 boring sky lights with Heki's, easy job, and no silly labour charges.
Johna
