Mini Heki fitting?
Discussion in 'Tech/Mech General' started by mulaz, May 7, 2009.
  1. mulaz
    mulaz Read Only Funster
    Apr 14, 2009
    97
    3
    Durham
    Have a new mini heki to replace my boring skylight. The box includes a small packet of stainless U shaped clips 10mm square? but cannot find any reference in the multilingual instructions.
    anyone shed any roof- light on these clips:Rofl1:
  2. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,190
    14,134
    Heavan
    Hi mulaz,
    I fitted two heiki lights in to my old van and they made a great improvement. I cant remember the clips you speak of? but if I didn't htink they were needed they probably ended up on te garage floor.:Doh:
  3. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,895
    6,155
    Mansfield,Notts
    Are they speed clips for self tappers (they have holes in them) and usualy slip onto plastic parts lining up the holes in the plastic with the holes in the clips, so as to give self tapper a firm hold and avoid splitting a plastic hole
    Geo
  4. mulaz
    Apr 14, 2009
    97
    3
    Durham
    clips
    Thanks but No i even double checked
    The only thing i can think of is to connect the 2 blinds fitted on the mini heki together.
    The clips have sharks edges so doing this would also stop them being removed??????????????????:Sad:
  5. zaskar
    zaskar Funster
    Sep 25, 2007
    992
    98
    UK
    If its what I'm thinging of, they clip onto the inner frame (inside the van) and are used to hold on the outer trim surround. Surprised there's only a couple of them but then mine are beggers for falling off. Have a look at the bottom edge of the inner frame and see if there's more there.
    :thumb:
  6. Geo
    Jul 29, 2007
    9,895
    6,155
    Mansfield,Notts
    Ah! me thinks i know what they are Imagine you have a fabric head lining and are cutting a new hole for the Heki Might they be used to secure the headling to the inner frame whilst the finish plate is installed, new instalation only parts:thumb:
    Geo
  7. mulaz
    Apr 14, 2009
    97
    3
    Durham
    Fully fitted
    Fully fitted in less than 1 hour and i didn't need then *%&*"! clips
    what a big difference
    recommended to all:Cool:
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,364
    18,054
    YO11 2BD
    hope you sealed it well mulaz.....
  9. mulaz
    Apr 14, 2009
    97
    3
    Durham
    sealent advice
    Rang caravan clinic Gateshead /Newcastle Based repair specialist to buy some sealant.
    He advised using sealant on a roll and said come down and i will give you some for free!!
    so anyone wanting good friendly advice Also recommended repair work give them a try:thumb:
  10. johna
    johna Read Only Funster
    Sep 8, 2008
    16
    HI, The clips are to fix the inner blind to the main frame,once you have fitted your skylight, simply push them onto your main frame at regular intervals, and carefully line up your inner blind frame work with them and push into place. No problem, just replaced my 2 boring sky lights with Heki's, easy job, and no silly labour charges.
    Johna
