Microwave.... (1 Viewer)
Another Lesley
138
117
North East
:Confused: Sorry, me again with the questions. I am Confused.com.......... Can I or can't I use my domestic microwave in the motorhome. We appear to have a difference of opinion in our otherwise quite peaceable home and depending on the answer determines who cooks dinner. :winky:
1948
444
49
surrey
hymer A class
since 2010
Yes and no is the answer .
You can if you are on electric 10 amp and above hook up
Cannot if you are not on electric hook up unless you have inverter which converts your van's dc current 12v to ac 220v current and a battery bank of at least 3 leisure batteries
Looks like you need to share the cooking to night
golly
2,006
69,706
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
If you are on hook-up then should be ok so long as its not too powerful, ours is 700w and works fine . I wouldn't want to use it via an inverter unless I had a massive battery bank.
A
Another Lesley
138
117
North East
Thank you very much for the info. I hate sharing the kitchen, so we flipped for it. I lost.:Sad:
11,849
14,089
You probably can, but I would not recommend it. For convenience it needs to be secured in the van, and moving it from house to van and back each time is a complete pain. Get one exclusively for the van, which can be a lower wattage/smaller one. You can get them quite cheap from internet or supermarkets.
We had one in the van but removed it as we preferred to use the space/weight for other things.
If I was getting one, this is the one I would get. Probably the smallest, lowest powered one on the market.
[ame="http://www.amazon.co.uk/Daewoo-QT1-Compact-Microwave-Litre/dp/B003SX0SNA/ref=sr_1_1?ie=UTF8&qid=1365448333&sr=8-1&keywords=compact+microwave+oven"]Daewoo QT1 Compact Microwave Oven, 14 Litre, 600 Watt, White: Amazon.co.uk: Kitchen & Home[/ame]
The low power is important because outside the UK some hookups are rated quite low.
Jul 28, 2010
1,710
617
The world
Small car
your Engine alternator will put out enough AMPs to run a Microwave on an inverter so you may not need lots of batteries
run engine before you turn on microwave and rev engine to 1500 RPM there should be enough power to keep battery charged through the cooking time
I know some who use a slow cooker on inverter when traveling
i have six 120AH batteries and a 220W solar panel
with a 45AMP three channel marine charger
1.5KV inverter runs any thing i need to run
also it has a 5.5KV generator that runs all 110volt equipment
great for weeks of wild camping
11,849
14,089
Am I correct in my calcs
A 700 watt microwave should draw less then 4 Amps
It's been a long time since I did ohms law
Afraid not. The 700w is the output. It will probably use about 1200 watts when running with a start up surge of around 1500w. There will be a plate on it somewhere to give the actual figures but probably a peak of around 6A on mains or 130-150A on 12v via inverter.
Oddly enough there is some sense in using a microwave on an inverter from your batteries even if you are on mains hook up if it is only a 4A one as often found in France. The microwave on the mains may trip the supply, while by using the inverter your batteries will be recharged more gradually by your charger and thus not trip the supply.
cruiser
4,220
4,953
northampton
coach built elddis 400
since 1978
cruiser
i have been lucky i have found a 500 wat .have not used it yet.i will let you know if it blows the fuse.:Eeek:
