Microwave power when parked. (2 Viewers)
Jan 4, 2012
2,242
2,023
somerset
Fiat Ducato
A few years now
Picking up my first M/H monday and it has a miicrowave built in.
I tried to operate it but it seems it is 240v only.
Is there a way i can use it when parked and not hooked up, off the batteries?
joner
canopus
6,140
10,265
rural Lincolnshire
Carado CV640 Pro
As Peter has said without an AC source (generator or inverter) the microwave wont run.
Should you buy an inverter, be warned, using any AC appliance which is hungry on current will hammer the battery(ies).
Best bet is only use Microwave, fan heater, Remoska etc etc when hooked up to the mains i.e. EHU.:thumb:
Bailey58
8,825
29,638
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
I power mine off an 1800 watt inverter, helps to have the engine running. Haven't got a dedicated supply so I just use an extension lead on the rare occasions I need to.
chatter
3,689
937
cheshire
5th wheel
dont forget that on start up like all electrical items it uses roughly twice the amount of power that it is rated at when fully running. e.g. an 800w item probably has a 1600w peak level on startup and using an inverter from your batteries takes more out than just whats needed for the item as it has to power itself as well
Most folk that want to use such items when not on hookup will have a genny which depending on what you want to use are usually from 1000kva to 2500kva and are usually of the pure sine wave type so as not to damage any electrical items such as tv, laptop satelite system etc which might only run on 240 mains normally
oldun
747
162
St Neots
VW Campervan
Since 2001
How much charging current does the engine alternator provide to the leisure battery on tick-over? Not much I would have thought mainly due to the fact that the alternator output is controlled by the engine battery voltage.
A 800W microwave would draw about 70 amps from the inverter so this means very large electric cabling and a 120Ahr battery lasting about 75 minutes.
Though much noisier and yet another inconvenience a generator seems much better. Thats if you have room and payload to carry a generator and its fuel safely.
Jan 24, 2010
2,440
4,850
Adria Twin
having witnessed haggers fitting his 1800w inverter this weekend - and watching the microwave in action off his battery bank...a large inverter run microwave is definatley feasible....if you have enough batteries, i think haggers has 3x110a
the microwave was pulling close to 100a (Nasa Bm1 showing this) :Eeek: but don't forget...unless your trying to do a whole chicken...most use of a microwave will be for minutes rather than hours
so...based on haggers microwave pulling 100a - that works out as 1.6a per minute of use, even on a 10 minute stint its only 16amps.. relatively easy to replace
so my view would be have a decent battery bank and it should be fine - and if you happen to have a B2B or solar panel...jobs a good un:thumb:
11,843
14,080
Agree with Bungy above. The microwave only draws about the same battery current as the hairdryer and both are only used for a few minutes at a time. Work fine off inverter.
Nov 6, 2008
3,944
40,801
Ramsey, Isle of Man.
Coachmen Concord 300TS
8 years with an RV
Mine only works on hook up. So, if i am not hooked up, back to basics, gas oven and hob. It's not difficult.
Craig
haganap
12,760
26,462
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
A B2B and a solar panel, there's a good idea, oh dam forgot, got them too. :Sad:
toys man i need toys. :Cool:
Jan 24, 2010
2,440
4,850
Adria Twin
if you get anymore your going to need one of Broken Link Removed
haganap
12,760
26,462
planet earth
having taken a wrong turn out of Cardington today and heading for 10 miles on roads where cars had to reverse for miles to get out of my way, and dog walkers shook there heads in disbelief, I most certainly do not want one of them :Eeek:
Jan 24, 2010
2,440
4,850
Adria Twin
:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
By page 4 of this thread my 1800watt Sterling is happily running my 1100watt full load current microwave
Bailey58
8,825
29,638
Norfolk and Toftir.
Sold
Sorry, only just seen Oldun's query to my post, I've never used it for longer than 2 or 3 minutes to heat something so not been a problem. My inverter feeds the roof aircon but I've cut into the feed to give me a 13a socket to plug a kettle into when parked in a layby, feeds the microwave too with an ext lead.
