mechanical problem (1 Viewer)
darklord
1,241
1,230
essex
coachbuilt
three years
those of you who weild a spanner occasionally, may like to chuck in your opinion on this one,.....to see if its the same as mine.
When i turn on the ignition, then start the engine, it fires immediatly but does not keep running, When I do it the second time it starts and runs normally.
makes no difference whether its hot or cold....first turn, no...second turn...away we go.
Its a 2005 fiat ducato 2.8jtd,.........................
Dec 6, 2011
11,593
25,424
South Wales
Coach built Adria
when you turn on the ignition do you wit a few seconds for the fuel pump to presurise the system and the injector heaters to warm up?
also
if you start the engine and it runs say 5 mins and you switch off, does it still fail to run on first attempt?
darklord
darklord
1,241
1,230
essex
coachbuilt
three years
Yes and yes::bigsmile:
43,331
49,460
Beats me....never come across this ongoing problem before :Blush:
what if.....turn on the ignition then turn off without starting then turn on and attempt to start.
does it start and continue to run then.
if it does, then that should eliminate the fuel side (air leak etc) and point to an electrical fault....possibly pump, immobiliser or a sensor failing.
Sep 23, 2007
1,710
1,970
Leicestershire
4 and many as a tugger
I am sure I have read this can be due a cam sensor fault. Not sure but I think it is due to the wrong gap.
Andy
Scout
3,959
121,327
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
Im sure mine does this as well, (heads a bit fuzzy at this moment) mines also a 2005?
mike mcglynn
Jan 6, 2008
2,700
32,552
St. Helens MERSEYSIDE
Autosleeper Warwick XL
A long time now
2.8 jtd 2006
Since I have had a new engine fitted in France :shout: my autotrail is doing this all the time :Doh:
Robert00
5
canada
I'm a newbie
Ok..I have a 1989 ford Ranger, 5 speed, with a four cylinder, Well the problem is..When you try to start it.. the starter won't turn over, you just get a grinding sound..I have put a new starter, cypinoid, and battery..Does anybody have any suggestions on what else it could be? i
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
ringgear on the fly wheel?
try pushing it foward in gear about a foot or try turning engine over manuly about half a turn,then try the starter:Smile:
greyman1
374
279
manchester
9 years motorhome / 10 years campervan
possibly damaged ring gear on the flywheel [remove starter , look at teeth on flywheel and turn engine by hand a full revolution, you will probably come across a small section where the teeth are mashed , hence the grinding !! ] solution . at best a bit of filing and at worse, gearbox out, flywheel off and fit new ring gear !! regards garry
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
You don't have to renew the ring gear after removing G/Box, , just heat the old one, it will expand enough from you to remove it, just a few taps with a ballpeen will do it. Then reheat and replace the ring but about 150mm further on, so new teeth where starter engages IN THE THREE POSITIONS it engages on the flywheel
Sorted:winky:
BobT
305
309
Norfolk
Mechanical experience
From my vast engineering experience I can tell you that it is a fault with something under the big metal bit on the front of the 'van. I suggest you call the AA or RAC.
darklord
darklord
1,241
1,230
essex
coachbuilt
three years
Thanks chaps, I was thinking it was the scavenge pump in the tank, but will have a look at the cam sensor.
Witht the ranger problem, I agree...mashed ring gear teeth. If that proves to be the case, it is possible to drop the gearbox, and remove the flywheel,..replace it after turning it 180%. Make sure the bolts are not single use before replacing.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
I've noticed this with many common rail diesels after changing the fuel filter.
They usually do it for a day or three,or until you give them a good blast down the road.
Must be a bit of trapped wind(air) in the fuel system,then they are fine until the next fuel filter.
