- Sep 25, 2009
- 797
- 1,392
- coachbuilt
- since 2004. Tugger 10 years on and off
Whilst cooking yesterday one of the gas rings was not putting out full heat.low flame.I thought it must be a faulty switch.Then heating went off.Thought it was empty gas bottle.so changed over to new one.lit gas hob faulty burner would light.changed over to another ring no problems.Untill i came to turn it off.I turned nob off.but the burner stayed lit.turned gas off.Decided to bypass magiscope.put a normal propane regulator on via a piece of gas pipe i use for cadac.All working now.Will get a new regulator when we get home.magiscope reg 80 pounds.But seen a manual regulator by gaslow 35 pounds.If pipe size is same can I fit this instead.I never use automatic changeover as its easy to forget and empty both bottles.Any advice appreciated
