lpg
Discussion in 'Motorhome Chat' started by lugnutt, Oct 15, 2009.
  1. lugnutt
    lugnutt Funster Life Member
    Sep 9, 2007
    1,183
    455
    wednesbury.westmidlands
    hi my engine will not tick over on lpg but is fine on petrol. lpg will run fine on motorways ect ,i just can't let the revs get low or she will stall ie slip roads ect .my gas man let me down as he was supposed to call this morning and not for the first time. so i am asking for advice please:thumb:
  2. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    There should be a slow running mixture screw on the vapouriser Dave.
    You don't say but I'm assuming you are running a normal carb/mixer setup?
    If it's multipoint injection, then I'm sure there's someone here that can advise.
    As It ticks over on Petrol ok I assume it's only an lpg/mixture setting.
    Steve.
  3. lugnutt
    Sep 9, 2007
    1,183
    455
    yes Steve mine is injecterd it is a imco
  4. Tony Santara
    Tony Santara Funster
    Jul 26, 2007
    1,494
    114
    Cheshire (ex Mancunian)
    Hi Dave
    I had a simmilar problem with my Winnebago Ford V8 , it wouldn't tick over and kept on cutting out on bends and islands , it ran fine on petrol .
    Turned out it needed a new idle control valve nothing to do with the LPG convertion diagnosed and repaired by Duncan ( Starspangledspanner)
  5. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Hi Dave.
    My carb is some 30 years old....so...I bit the bullet and have just installed a brand new one....
    It was showing some signs of wear and I figured that if it helped the lpg conversion setup and running, and the fuel consumption it had to be a good investment.
    BTW If you ever need and bits...especially exhaust pipes making to your specs and drawings...I can highly recommend Cliff @ Carolina Classics....
    cliff@americanmotorfactors.com
    I sent him the drawing and he got it back within 3 days....BOUGHT THE SILENCER/MUFFLER AND GOT THE TAIL PIPE MADE UP TOO.
    Now I am very impressed with that as everything has to be made to measure.Fits perfectly.:thumb:
    VERY reasonable price too.You'll be surprised.
    Hope you sort it.
    Might well be worth talking to Duncan as Tony has mentioned as it is injected.
    Steve.
  6. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,863
    roche cornwall
    hi steve , on reading your last post i dont think it would make any difference to running on lpg as you only use the throttle butterfly on a carb .should make the petrol running better , but do you use much petrol or stick with gas. cheers alan.
