Lost my motorhome virginity and 0.4amps
Discussion in 'The Beginner' started by themountaintiger, Mar 28, 2010.
  1. themountaintiger
    themountaintiger Read Only Funster
    Sep 27, 2009
    355
    63
    Lancashire
    Hi All
    Just done my first trip in swift sundance motorhome, I parked up (on chocs), managed to switch internal lights on (well misses sussed that one out), made a cup of tea, turned heating on (and off), turned captain seats around and did a number 1 and yes a number 2 in the toilet!! :Eek!:. I even started to mess about with the lights to see what used the most amps, so im beginning to learn a bit about it. Motorhome virginity lost!!! :RollEyes:
    What im a bit confused about is that on return from 100 mile journey after a days use without hook up, my control panel is saying that the leisure battery now has 13.5v in it but there is 0.40amps leaving it (there is an arrow pointing away from it), Is this a present from the leisure battery to the cab battery? or have I left something on (although Im sure I havent). I cant work out that if I stop looking at it will it revert to 0. Is it something to do with electric steps being out as Im looking. I suppose I could retract them and parachute out.:helpsos:
    Felt good today cos I got my first motorhome waver, who was heading north 10 miles north lancaster on M6, thanks mate, my misses though thinks ive lost the plot!!
    any advice thankfully received...
  2. Exustrek
    Exustrek Read Only Funster
    Sep 25, 2007
    30
    Biddulph, Stoke-On-Trent
    Hi mountaintiger
    0.4 amps current draw is most likely the frost protection on your Truma boiler.
    Bryan
  3. themountaintiger
    Sep 27, 2009
    355
    63
    Lancashire
    Leisure battery
    Hi Bryan
    Would this actually drain the leisure battery or is it too small an amout to do this?
  4. Exustrek
    Sep 25, 2007
    30
    If your battery is in good condition i guess it will take quite a while for 0.4 amps current draw to drain a leisure battery.
    We have a 220 amp battery bank & ours shows a constant drain of 0.2amps, the longest i've left it between charges is 2 months, battery was at 12.1v after standing for 2 months, about 50% charge, try not to let your battery drop below 12v.
    Our control panel allows us to isolate the leisure batteries if the van won't be used for a considerable length of time, which of course means the only loss of charge is through self discharge. If you do this during winter months it's important to make sure your water system is drained down.
    Bryan
  5. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,762
    3,259
    Eastbourne East Sussex
    It will if you leave it long enough. 0.4amps will discharge a 110 AH battery to effectively flat in around 6 days. However 0.4amps sounds high just to keep a valve closed so perhaps your battery drain is something else.
  6. themountaintiger
    Sep 27, 2009
    355
    63
    Lancashire
    ill have to check
    Ill check tommorrow with a fresh pair of eyes.....:Eeek: to see if it is something ive not done
  7. Exustrek
    Sep 25, 2007
    30
    nearlyretired is probably right
    I've just been out & checked ours & current drain is only showing 0.1 amps.
    If you've turned off all the obvious stuff a couple of things that catch some people out are TV signal boosters & the frame heater switch on the fridge freezer.
    Bryan
  8. themountaintiger
    Sep 27, 2009
    355
    63
    Lancashire
    Hmmm
    Ive just bought the motorhome Tuesday and realised that the TV signal booster had been left on by previous owners this morning when I tried to get a tv reception. So I have definitely switched this off.
    If I write down here the things I used tday/yesterday that might help me
    Used
    ceiling lights (off as it is dark inside throughout)
    roof lights (off as it is dark inside throughout)
    Radio (now its in house)
    Truma Heater used it on Gas then turned it off (is there anything electric in there)
    Gas Cooker to boil a kettle via gas
    Steps (were out when checking control panel, perhaps I should enter via cab)
    (just tried entering through cab, amps still the same)
    Not Used
    Fridge (not used but I did move button to a 0, not sure what it was on before)
    Boiler (The motorhome was running dry, no water or waste so boiler etc not on. (hadnt got to that instruction page yet)
    It is very silent in there with no lights or anything else on (to my knowledge) but still showing 0.4amps, is it anything to do with alarm system or would that run off cab battery
  9. themountaintiger
    Sep 27, 2009
    355
    63
    Lancashire
    Sundance control panel uses amps itself?
    Reading through another motorhome forum someone has mentioned that the 0.4 amps the control panel is telling me im losing, could be in fact the control panel itself (swif sundance 630g 2007). Is the easiest way of testing this just to measure the battery charge levels say an hour after stopping after a journey, and then again 2-3 days later to see if in fact there has been any leakage?
    ta in advance
  10. oldun
    oldun Read Only Funster
    Mar 23, 2008
    748
    160
    St Neots
    Do you have TV aerial with an amplifier turned on or an alarm that always draws a small current?
    There are quite a few things that continually draw a small current.
    Or is the meter giving you a false value?
  11. JayDee
    JayDee Funster
    Oct 7, 2007
    1,312
    166
    N. Devon
    Ignore her. It's one of the bonuses of motorhoming. :BigGrin:
  12. TonyIsh UK
    TonyIsh UK Read Only Funster
    Oct 31, 2008
    120
    Being a motor home aside, you may be wise to learn how to use a voltage / amperage multimeter, Cost about £5 from Maplins or similar.
    With this you can measure the ACTUAL current and volts at the battery. On my M/home the display is always 0.6 volts lower than the voltage at the battery terminals.
    0.4 amps from a battery at rest is quite high, even a engine battery with an alarm, FIAT power hungry ECU and the dreaded radio standby voltage, should not pull this much.
    Rgds
  13. thehutchies
    thehutchies Funster
    Aug 31, 2007
    1,503
    1,620
    The Wheelèd Shed
    That might have been us, on our way to Scotland.
    We wave at everyone :thumb:
  14. Aspenshaw
    Aspenshaw Read Only Funster
    Mar 28, 2010
    22
    Wirral
    0.4 amps
    Our Hymer loses this amount. It's a combination of things such as the Truma frost switch and the control panel. We always switch off the electricity in the van when not in use but it still drains this amount. We have two batteries and can plug the van into the mains on the drive. Otherwise, Hymer recommend switching off the Elektroblok which is what controls the battery. I think that stops the drain of 0.4 amps.
    You do have to watch this drain because it will flatten your battery quicker than you think.
    Swift have improved their customer service and so if you cannot find the cause and put your mind at rest, email them with details of the van and any reference numbers on the panel.
