Locker Lights - Bessacarr E560 (1 Viewer)
Feb 9, 2008
4,094
5,915
SW Scotland
LP Coachbuilt
Hi, had a couple of lights go, the courtesy lighht by the door and one of the locker lights over the bed. The courtesy light was a halogen capsule, sourced from local electrical shop no problem. The locker light is a halogen MR16 12v 10w closed dichroic.
Problem, I have only been able to source an open replacement, does it make any difference? There are plently of closed 20w available but the only 10w I could find is open.
I don't see that it makes a whole lot of difference, if you touch the glass of a closed bulb its very hot, the open bulb will just be a bit hotter.
Anyone any ideas?
Rgds
Bill
43,337
49,540
are you sure its 10w bill,
i cant find a 10w dichroic either.
cant see it making a lot of difference.
if its only on when you go in the locker why not fit a 20w to be safe.
Braunston
1,408
7
Hi,
You can get the 10w from Maplins (sometimes as they don't always stock them) also if you search online there are a number of places that sell them, have a look at the link below (hope it works) we replaced ours with LCD's but the light is quiet a bit different,
I have tried to search on line for the reason for the difference e.g closed and open and all i can find is that they say the open ones should be used in closed luminaries,
hope that helps
