Levelling Ramps Problem (1 Viewer)
mick noe
Apr 14, 2009
638
539
near Boston Lincolnshire
low line
we use millenco triple levelling ramps and do need them even on level ground as rear is always higher than front even fully loaded with scooter in the garage. But when I apply handbrake it always moves back a couple of inches (seems to be as the brakes take up the load [alco chasis]) this nearly always sets the tyres on the pointed ridge between the 'cups ' that the tyres are meant to sit in. I am worried this will damage the tyres in time. has anybody made there own ramps and if so out of what? as the flat top type do not appear to be made in high enough versions.
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
When you have reached the height you want to be at...
Put the handbrake on and put the vehicle in first gear and turn off the engine .. let the clutch up and this will normally stop that bit of a backward run.. (y)
Puddleduck
12,387
44,009
Scottish Borders
Without at present
On and off for many years.
My Brother-in-law made his own levelling ramps many many years ago..... he used hard wood salvaged from furniture dumped at the local tip.
Puddleduck
12,387
44,009
Scottish Borders
Without at present
Probably lighter than the Milenco Quattro ramps as well .......... ;)
Probably not......... he did try to sell the design (it was before the availability of the Milenco offerings). Not sure how successful he was. I do know he had some plastic mouldings done for them.
Puddleduck
12,387
44,009
Scottish Borders
Without at present
That is what we do, aiming not to overshoot again.
Again?????? It is one of my fears that I will overshoot as I usually drive the van onto the ramps.
Generally I do as @old-mo suggests...... letting the foot brake off ever so slowly :)
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
the easiest answer is to select a site that makes you level in the first place. never used them in the last 45 years.
DuxDeluxe
14,660
72,840
Planet Zog
A woosh bang van
One of my greatest fears as well.......... apart from growing old and losing my feathers, that is ;)
DuxDeluxe
14,660
72,840
Planet Zog
A woosh bang van
Not so easy when a lot of vehicles have a higher stance at the rear axle compared with the front, though
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
well maybe I have just been lucky with my last 14 vans, depends how out of level you are prepared to put up with I suppose.
MattR
4,105
39,096
Beds
Panel van
Years
My ramps have the scars to prove that sometimes, co-pilots get distracted when guiding the driver up ramps. To be fair, we were trying to get three wheels onto ramps but hand signals to continue should stop once the top has been reached - not after.
Feb 27, 2011
14,761
76,255
You wouldn't accept your house not being level so why accept it in your van.
One and the same for me. I got rid of my levelling ramps donkeys years ago and will park at whatever angle the land says I must be at. Got a sponge for bailing the shower out and other than that I don't notice any slope.
I really hope no one else decides that having the van level is essential, I got rid of my TV at the same time as the levelling blocks went so the entertainment value of watching either motorhomers spend hours getting level or caravanners setting up is priceless :whistle::p:LOL:
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
Must admit I am too lazy to dig them out. I try to choose the most level I can get to save mum complaining the water isnt running away properly.
Unless the slope is bad then why bother.
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
You could get someone to chock the rear wheels before you turn the engine off ( of course you need to buy decent chocks first)
We rarely use ours and have often seen vans on chocks on level sites when the van is clearly at an angle and wonder why.....
JJ
Mágica
May 1, 2008
19,259
48,060
Burstner Privilege T
over 50 years
Obviously motorhoming Masons need to be on the level...
Levelling blocks seem to be necessary sometimes if you use campsites with marked, regulated pitches.
We freedom loving Freeloaders are not restricted to parking on "allocated" spots and therefore are able to choose stopping spots where the kettle doesn't slide off the cooker...
With reference to the OP... I doubt a ridge in a plastic ramp will cause any damage to a modern vehicle tyre. If it did I would change my tyres!
JJ :cool:
Cal54
3,807
62,118
Southport, UK
Leisuredrive Renoir
Since 1996
I use the same approach as Mo - leave in gear, apply handbrake and switch off, and then take foot off the brake.
Nov 18, 2011
11,862
43,124
Planet Earth
A van
Over 25 year's
I carry ramps but usually only use them when the van brakes down to give me a bit extra room to work on it
apart Frome that unless the kettle s sliding off the cooker we don't bother
we just sleep head up slope.
bill
Abacist
3,757
10,906
Devon
N & B Arto 88F Tag
since 2013
I had a set of Milenco 4 tier ramps and no longer use them.
First time I tried to drive onto them forwards on the front wheels - they scooted right underneath the tyres and ended up 10 yards away in front of the van - the surface was obviously too slippery.
Another time under the rear wheels one dug into the ground, tipped up and stove in the skirt around the base of the MoHo.
Lastly, having got on successfully, when I came to put them away again a load of the plastic honeycomb support was cracked and broken and that's with a 4.5 ton van when fully laden.
Got myself a pair of 3 tier german ramps that are man enough for the job.
Have to say that I like to be level enough not to have to bale out the shower because sod's law dictates that the drain hole will always be on the high side when we are not level leaving a big puddle of dirty shower water to have to be removed!
Puddleduck
12,387
44,009
Scottish Borders
Without at present
I'm not sure what the Milenco 4 tier ramps have as a rating... our van is 3.5tonnes max and is usually around 3.2. I wouldn't use them with a heavier van :)
Levellish is fine with me but we have used the ramps a few times and been grateful for them as ours is one of the "nose down" types. If you get a warden who insists you park nose out or hab door to one side or the other it isn't always possible to park on a slope as you would prefer.
Feb 27, 2011
14,761
76,255
That's very true. The hole is ALWAYS!!! at the wrong side no matter where I park :D.
I now have a jug and a sponge. Fill jug up using sponge, empty in sink. Only takes two minutes then I can dry shower so I don't get wet feet using toilet after.(y)
As for kettle sliding off hob or falling out of bed. Never experienced that even on extreme slopes...
I do find it a little irksome when my pen, ciggy or other items start rolling aross the table. But I now have slots for everything anyway so not seen it in a while.
I think as a fulltimer you slowly become more tolerant of the tiny issues like this and give up fighting them. Once you accept things like this and learn to live with them life becomes a bit simpler. The thought of messing around with levelling blocks now is an absolute no no for me.
18,040
48,161
I think the different approaches aired here are between those who frequently "wild camp" and perhaps those who use more established MH parking. We use ramps where we have to and it is very quick and easy after a bit of practice, it certainly takes less time than bailing out the shower - which we have done when for one reason or another we couldn't get level. :)
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
Couldn't agree more. As previously posted by Popeye you wouldn't accept your house not being level so why accept your van?
That was pappajohn not Popeye, can't take the credit for that I'm afraid, or the blame.
I have a set of Millenco Quattros but I have just bit the bullet and had the E&P Hydraulic leveling system fitted to Ruby, used twice now, once at Newbury and again down in West sussex last week. These.
They say you're level in under two minutes but I found that it is under 20 seconds.
Feb 16, 2013
19,749
52,119
uttoxeter
ambulance conversion
50 years
Can't follow this, if the shower hole is at the wrong end of the slope, can't you just turn the van around
