Leisure battery (2 Viewers)
Busker
24
Warwickshire
April 2016 Lots to Learn!
Hi folks This is basic but...Is it normal practice for the leisure battery to be included in sale of motorhome unless dealer states in advert otherwise, and what would a typical battery cost and weigh. this would be for a PVC. Thanks
Jul 29, 2013
9,071
18,565
Salisbury
Hymer B678DL A class
Wouldn't buy a van without one and certainly wouldn't pay extra for it!
2,586
8,837
Lincs
Globecar Campscout
The dealer will probably (& quite sensibly) fit the cheapest thing he can find. You might be better to negotiate a price reduction & fit whatever you want. It depends how much you intend to rely on it - if you are mostly on sites with EHU, then get the dealer to supply & fit - it won't matter much what he puts in. If you plan to fit solar panels & rely on your stored power, then it would be better to specify everything, including the battery, yourself.
You also need to know what the in-build charger is capable of - no point in buying AGM or Gel batteries if the charger is only designed for the standard wet acid type. Having said that, a lot of people do get away with using AGMs with a standard charger.
MC 55 FUN
3,432
6,347
Rural South West Wales.
2015 Majestic 195
Since 20th Feb' 2016
Make sure the stealer fits a proper leisure battery & not an ordinary car / van engine starting battery
553
544
Bedfordshire
Carthago
Since Sept 2003
I must give credit to Southdowns at Portsmouth here. When I bought the van last April it needed a new leisure battery, which they said they would fit. I did not specify anything, and I rather assumed, as above, that something cheap would be fitted. I did a lot of research and decided that when the time came I would install Varta Professional dual purpose batteries. I then discovered that that was exactly what Southdowns had fitted, and two of them, to boot. So not all dealers are niggardly; well done.
Busker
Busker
24
Warwickshire
Thank you to everyone for taking the time to reply and the welcome advice, have got a lot of homework to do. Oh and that looks like a fine bodhran,. TheCaller Thanks again
2,586
8,837
Lincs
Globecar Campscout
I've heard other people say good things about Southdowns. (y) Always nice to hear about someone who does it right - they do exist; it's just that mostly we hear about it when things go wrong!
2,586
8,837
Lincs
Globecar Campscout
It is. (y) That particular one isn't mine, but I have two by the same maker, one of which is very similar.
Made in California by a chap from Grimsby! :)
11,956
16,570
Bought my SH Hymer from them a couple of years ago - couldn't fault them.
