Leisure battery issue (2 Viewers)
Douglas1
38
14
Cheshire
Hobby Toskana
3 Year
Can anyone help on this.I have a Hobby Toskana 750,I use the inverter now and then,I'm aways cautious of draining my 2 leisure batteries, so just limited use now and then.I do have 120w solar panel as well which keeps them topped up.
Today I used a 900w hairdryer,I switched the 2k inverter on and I also switched the engine on,everything was fine until i switched to full power on the hairdryer,the volt reading went from 12.7 down to 0.1 and it cut off.
A volt meter shows both engine and alternator are charging and working fine and give a reading of 13.5.But the engine battery has stopped charging the leisure batteries, I've checked the fuses under the drivers seat,all are ok. There seems to be no power at all to the leisure batteries from the alternator on engine startup.
I've hooked up to mains and all batteries charge with symbol on panel showing this.We do a lot of wild camping so if anyone has any thoughts on this,I'd appreciate it.
Both leisure batteries and engine battery are fairly new and do hold their charge.Is there a fuse or something stopping the engine battery charging the leisure batteries?
Jul 29, 2013
9,071
18,566
Salisbury
Hymer B678DL A class
Sounds like an inline fuse between alternator and batteries somewhere does your starter battery still charge? There may be a separate cable connecting alternator to leisure ?
Jul 13, 2008
3,739
3,882
Low profile
As I said on FB, pretty sure there is a 50amp fuse. Mine is right next to the leisure battery. :)
Douglas1
Douglas1
38
14
Cheshire
Hobby Toskana
3 Year
Yes but we're, I was hoping someone had the same issue and could pin point were to look.
Douglas1
Douglas1
38
14
Cheshire
Hobby Toskana
3 Year
There are two 50 amp fuses next to the leisure batteries which are fine.
Jul 29, 2013
9,071
18,566
Salisbury
I think I've read in a previous thread that perhaps you need to reset the control panel I'm notsurehow you would go about that though.
Douglas1
Douglas1
38
14
Cheshire
Hobby Toskana
3 Year
Anyone no about resetting the control panel?
Jul 29, 2013
9,071
18,566
Salisbury
Try this or search reset control panel
Discussion in 'Link Removed' started by Link Removed, Link Removed.
andy63
4,672
15,018
south shields
since 1990
I don't know your vehicle but I'd be surprised if there wasn't a relay involved in that circuit. . Mine...a chausson has a relay that connects engine and leisure batteries when the engine is running..so could be a relay fault...if it isn't a fuse..
Andy.
11,956
16,570
The leisure batteries won't drop to 0.1v just because the alternator stops charging no matter what load you place on them. Are the hab electrics working?
Douglas1
Douglas1
38
14
Cheshire
Hobby Toskana
3 Year
The only thing not working is the outside step.This has to be operated with the switch,were before it would go up automatically as soon as the engine started.
11,956
16,570
OK. So does the voltage across the leisure battery increase when the engine is running and does the fridge work on 12v?
mike mcglynn
Jan 6, 2008
2,700
32,552
St. Helens MERSEYSIDE
Autosleeper Warwick XL
A long time now
I had a similar issue it was the fridge and step relay fuse next to the engine battery its the 12v supply to the hab side on an older Autotrail maybe yours is the same .
karl c
231
247
since 2010
sounds like you my have overloaded the alternator, If your not getting a charge + the two 50 AMP fuses are ok.
If your with the AA or RAC get them to check out your alternator.
andy63
4,672
15,018
south shields
since 1990
To me that again points to a failure of a main relay linking the batteries... that relay would be activated by an engine run signal...as would your step closing relay... sounds like you've possibly lost that signal ... check your smaller fuses as well..
My engine run is on a 3A fused circuit. .
Andy
Douglas1
Douglas1
38
14
Cheshire
Hobby Toskana
3 Year
Found the fault, it was a 50 amp midi strip link fuse, located in a black box,close to the engine battery.Which is under the floor on the passenger side on my vehicle.
The leisure batteries are now charging when the engine is on,the step also comes up and engine battery on the control panel is back to normal displaying 13.9 volts.
Thanks to all for your advice.
andy63
4,672
15,018
south shields
since 1990
Great that it's sorted... a happy outcome.. so does that mean that you run your inverter only off the leisure in future without starting engine???
It will be the fuse at the engine battery end of the circuit.
D.
Sounds like you were spot on...(y)
Andy
19 kenny 42
20
11
ackworth yorks
hobby 700
hAVE A LOOK NEAR THE RELY BOX YOU SHOULD FIND IT AT THE SIDE A 40 AMP
motorhomer
680
418
South Shropshire
If you do the sums, a 900 watt mains hairdrier through an inverter is at least 75 amps at 12v. That is a very substantial current and will blow fuses, burn out relays etc. Most of the fuses will be 40 or 50 amp at most.
My wife reluctantly uses a 100 watt 12v hairdrier which is still a large current - 8 amps - although, if we are honest, its not the worlds best hairdrier. but it doesn't blow fuses!
