LED lighting -finding higher output bulbs (2 Viewers)
Mousy
3,486
20,326
Sa15 2DG
Hymer S840 Merc auto
The led bulbs in our Moho are not very bright and I want to replace them with the highest output I can find. I have looked online and there are thousands of sellers and tens of thousands of different bulbs. If you have bought some recently please can you let me know what the highest output was you found and where you bought them. Below are some photos of the bulb type which are built into the surround of a skylight. I think the fitting type is G4. Thanks Martin
Peter A Forbes
270
184
Rushden, Northants, UK
Mercedes 614D
G4 is the Bi-pin arrangement, but there are dozens of different formats.
The bulb you have shown exhibits one of the issues with radial fitting bulbs, in that light output is poorly distributed around the bulb envelope, and needs a decent reflector to gather the light and direct it.
We bought disc-shaped 2W bulbs with multiple LED's all facing the one way, these would go into most G4 holders, sometimes the pins needed shortening.
They shove all their light out frontwards with none wasted, but it does depend on the lamp they are fitted to.
We have used them in 4's and 5's and 8's in old-style flourescent luminaires, plus our reading spotlights have them.
I'll find some pictures.
Peter
GJH
29,450
38,827
None, now sold
2006 to 2022
I've always found Aten helpful and good quality as well. They do a Range of G4 LEDs in different formats to suit different fittings. I've also used LEDs from this country and China bought on eBay. They work OK but aren't such good quality as Aten.
There is also a difference between Warm White and Cool White. Some people prefer one and some the other. If you can wait until a show, the suppliers there have boards displaying the various options for comparison.
Feb 24, 2013
13,090
101,509
Bolsover, Derbyshire
Hymer S800
not long enough
I thought the 'Thanks Martin' at the end of OP was Dawn saying thanks to Martin for giving her the bulb type
Then Martin (Funflair) replies to Martin so I have to go back to OP to see what is going on
So Martin welcome to the forum
We have bought all of ours from HomeWatt, for house and MH, again good advice good service, family owned business
LED's have really come in the last 4 years or so, you can get 6W versions of the G4 bulbs that will nearly blind you, Homewatt have options for daylight white or warm white
Not the cheapest we could have bought but great service (y)
11,932
9,097
Hi David Daylight white /warm white are the same (both bright) It's cool white that is dull -er;)Just a bit of useful info for others :D--I have had cheap Chinese bulbs for a good few yrs with only 1 failure which is more than outweighed by the price difference --Anyone who thinks their £5 led is better than £1 Chinese is fooling themselves -they are probably all made in the same Chinese factory -sure they will exchange a £5 one FOC it only cost them £1 :D:D:DLeds are getting better all of the time ;)
terry
edit I am going to have to do some more research now because I have forgotten if it's cool or warm that's the same as day white :swear2:
EDIT apologizes David you were right it's daywhite and cool white that are the same -warm white is the duller one :rolleyes::D
GJH
29,450
38,827
None, now sold
2006 to 2022
I'm sure you're right about some Terry but there is a definite quality difference between the different suppliers of the ones I bought almost 3 years ago. Aten certainly used to assemble their own. :)
11,932
9,097
Hi Graham -
From Chinese parts? :D:LOL:
Dec 24, 2009
1,073
15,722
bedworth warks
c class
2009 previously a tugger for thirty years
We changed the spot lamp bulbs in our Bessacar to LEDs originally as we used them quite a lot in the rear lounge. Sometime later when I thought one of them had blown I bought some SMEDs. The light output from them was fantastic in comparison to LEDs it was almost unbelievable the difference they made, its what's used in Cree torches. They may be a bit more expensive but well worth the difference if you want bright lighting.
11,932
9,097
Don't know the difference between SMEDS AND LEDS ---CREE make the leds -the big difference is between DAY/COOL WHITE and the WARM WHITE (duller )
terry
Sep 25, 2009
794
1,386
south yorkshire
since 2004. Tugger 10 years on and off
terry
Hi Terry. Some of the Chinese may be good.I bought some.Had six out of the bunch fail.These were replaced foc, only for three to overheat.Luckily we were in the van when we smelled burning.I could not touch the leds.when I removed them they fell apart.I now have had Leds from Aten Lighting.Not one failure or overheating.
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
i ordered 2 extra spots for my van that arrived with smashed glass shades, the light with shade is near useless anyway as not directional enough. Would these MR16-18L PROTECTED (copied from bedazzled site above) fit please? http://www.bedazzled.uk.com/12v_LED_Bulb_Replacement.htm#G4Ttype
pic of my spot. or if anyone can
recommend a shaded lamp I would appreciate it (to use without shade)
Dec 24, 2009
1,073
15,722
bedworth warks
c class
Took this off the internet!
What is SMD/LED Lighting?
Surface Mounted Diodes (SMDs) are the new generation of LED lighting. They are three times brighter than the older LEDs and available in warm white, which means about the same colour light as your normal bulbs. Lovely. No more blue tinted lights which leave you feeling cold and miserable.
Why Select SMD/LED Lighting?
There are many benefits from using the SMD/LED lighting over other lighting solutions that have helped to replace incandescent lamps found in architectural, commercial and industrial applications. Some of the benefits of SMD/LED lighting include:
• Increased performances and brightness.
• Lower production costs resulting in better value for the consumer.
• Lower energy consumption.
• Lifespans of up to 50,000 hours.
• Significantly more environmentally friendly compared to other types of lighting.
• Wide variety of colours
Sep 23, 2013
2,586
8,837
Lincs
Globecar Campscout
I would have thought the G4T-18Lb was a closer match size wise, but then you need the shade. I think the MR16-18L would fall out without something to support it - I had enough problems with something similar to the G4T-18Lb falling out. From memory, I suspect they were these.
I know that G4T-18Lb doesn't do what you really want, which is to dispense with the shade altogether. I don't know what the answer is - the shades break & if they don't, then the whole unit snaps off the track, because the lugs that fit into the track are tiny & therefore very weak.
Did you get your spots through the M/H dealer, or did you find an alternative supplier?
I'll be interested in any solution that you find.
11,932
9,097
Seems I bought smleds without even knowing the difference :D does not sound like I was so lucky with the new phone :oops:
terry
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
1994 and beyond...
the german dealer sent them to be. I think I see what you mean re lamp not sitting in but the tiny lamps (G4? in photo) seem to sit there OK, the shade dont touch the lamp. Or is it because these other lamps are bigger?
also the G4T-18Lb you mention would surely look horrible without a shade and not be directional?
Sep 23, 2013
2,586
8,837
Lincs
Globecar Campscout
I would have thought that the ones designed to replace halogen spots (the MR11 & 16 series) would be too heavy to be supported only by the pins. I think they usually fit in a holder than supports the outer rim as well.
The G4 series are designed to be self-supporting inside a shade & certainly would look pretty horrible without one. They are non-directional, but as such are a like for like replacement for the non-directional halogen lamp they replace. The one over the dinette fell out on one journey, but the ones over the beds have stayed in ok.
I know a like for like replacement is not what you are trying to do - you want to replace a 36o degree shaded halogen with a non-shaded LED directional spotlight. I'm just not sure there is a lamp of that type that will hold secure in the lamp holder you have.
I was happy that I'd managed a like for like replacement, which was all that I had set out to do, but I do agree that it would be a further improvement to convert the fitting to a directional spotlight.
I may dispense with the track altogether & just get two directional spots, one at each end of the existing tracks. We do tend to have them positioned at one end of the track or the other. That won't be a cheap option, because I'll need 6 fittings to replace the three tracks.
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
1994 and beyond...
Hmmm...........thanks for the eye opener
I may just buy one lamp to see if it works or not, watch this space:)
If I could find an alternative metal shade might be an idea as well or maybe make some...
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
1994 and beyond...
just tried as an experiment using a 20watt 12v halogen lamp from indoors to see if it works. Well... it does, it sits in firmly, proper spot effect throwing light forward. now before I order the similar enclosed LED's. what would be the best to get i wonder.... a single led or a cluster of three? obviously the danger is hiting and breaking it, not much chance up front in lounge but over bed may be will mount on far side of each other at ends of track as the caller suggested, and keep fingers crossed. would look at it more seriously but considering changing the van....
