- Dec 31, 2010
- 2,646
- 5,851
- Frankia Platin i7900
- Since 2010
ABS plus the LED,s don't get anywhere near the temps of filament bulbsThey look good, what material did you use? As I can't see PLA lasting very long.
It's my son who does it I just give him the projects to do cos I am to thick to the design stuffThis is great, nice work. I’ve never used 3D printing before, did you have to design this yourself or was there a blueprint for it online somewhere?
I have that problem, I have enough problems with PLA don't think my printer will handle ABS very well, even if I could design it.It's my son who does it I just give him the projects to do cos I am to thick to the design stuff
Think you need a hotter print head Lenny for ABS, the youngins are a wizz with the softwareI have that problem, I have enough problems with PLA don't think my printer will handle ABS very well, even if I could design it.
It is the lateral spred that blinds oncoming traffic when passing on country lanes.Before I start, I know that most LED bulbs are not e-marked, and they work much better in general with projector headlamps rather than the old fashioned reflector headlamps that are fitted to Fiat Ducatos.
I have fitted these knowing that they aren’t authorised for road use, so please don’t remind me that they don’t conform thanks.
The reason that I’m so impressed is because over the years I have tried all sorts of bulbs in all my cars with differing results, but these have an identical beam pattern to the original halogen bulbs which suggests they won’t blind other road users. In the past I have removed bulbs that are too bright or have an awful beam pattern because I do not want to blind people. I just want to be able to see where I’m going.
(Frankly I think that halogen headlights should be banned as they are so dim, rubbish and dangerous.)
These LED bulbs were recommended by Bob Earnshaw on YouTube. His video is HERE and the link to Amazon is HERE.
If you decide to give them a try, remove the bulb base from the LED bulb and fit that into the bulb holder in the headlamp first. Then, fit the bulb and then twist until the bulb is VERTICAL** in the headlamp. Tuck the connectors in, leaving a bit of space for the headlamp adjustment mechanism to move freely.
**VERTICAL bulbs ensure that the beam of light is spread outwards, which reflects properly from the back of the headlight outwards, conforming to the original beam pattern. Any other angle and the light is cast all over the place. If you put them flat, the beam pattern is just awful and a telling off by pc plod would be imminent because the light that shines down from the bulb reflects upwards - into people’s faces.
I’ve attached some photos (LED passenger side, original candles driver side) and will update this thread once I’ve driven down a dark road somewhere to let you know how they actually perform in use.
EDIT: Don’t bother with the other LEDs that Bob tried in his video, the reviews look awful. I bought 2 pairs of the ones linked above, for dipped and main beam.
I've got loads of lateral spread around the middle with this lockdownIt is the lateral spred that blinds oncoming traffic when passing on country lanes.
Took the van for a short drive last night up a dark country road. Wierd driving with white lights when you are not used to it.Sounds good! Let us know the results when you manage to get out
My van dims the running lights in both scenarios. Which van is brokenOne thing I forgot to mention and I've just been and double checked.
With the LED's the DLR's don't turn off just go slightly dimmer, with the halogen bulbs they turn off as they are supposed to.
Not good, what type of headlamps do you have as the beam pattern with my projector lamps looks fine same as the halogen.Bad news folks. Just had MoT and... (the naysayers and told-you-sos will love this!)...failed on only two counts, both to do with headlights:
Light source incompatible with headlamps, and
Beam pattern non-compliant.
The technician was amazing. Took me into the bay and explained, using the MoT tester’s guide book, what the ideal pattern should look like. He then put ordinary halogens into one side and left the LEDs on the other, put the beam setters on and showed me the difference. The LEDs had an awful beam pattern which looked a bit like a bow tie, with nothing in the middle.
He said he owned a Ducato-based MH and had fitted Osram Nightbreamer Lasers, the latest iteration. He was sure I’d notice a major difference so I gave the go-ahead to fit the laser nightbreakers on both sides.
Astonishingly, the nightbreakers gave far better light than the LEDs. I can actually see where I’m going now (although I only have the authorised journey back from the MoT garage as proof) and I’m delighted with the result.
I was so hopeful that these Katur LEDs would be the answer, but they were not, unfortunately.
Brilliant posts thank you for sharing your experiences.Bad news folks. Just had MoT and... (the naysayers and told-you-sos will love this!)...failed on only two counts, both to do with headlights:
You might be OK Lenny, if your projector lenses correct the beam sufficiently. Maybe if you can find a friendly garage that will put the beam setters on for you, it can be double-checked before it comes to test time?Not good, what type of headlamps do you have as the beam pattern with my projector lamps looks fine same as the halogen.
Did you rotate the LED's to get the best beam pattern?
A couple of the videos where people have tested them said they didn't think they were worth fitting to reflector headlamps.They are reflector units (Ducato X250) and rotating did not help at all. The beam pattern was a bit like a bow tie when viewed through the beam setter, so there was no light in the centre where it is most needed, then it spread out on both sides.
Yes I think I can get that done.You might be OK Lenny, if your projector lenses correct the beam sufficiently. Maybe if you can find a friendly garage that will put the beam setters on for you, it can be double-checked before it comes to test time?
The Osram Night Breaker Unlimited come out better on tests.Brilliant posts thank you for sharing your experiences.
you mention the Osram Laser, this link may help owners find the right replacement Osram Bulb ( I suspect Osram may have a sudden spate of orders for these )
OSRAM Automotive | OSRAM Automotive
OSRAM provides the perfect vehicle lamp for every use and every requirement. Whether in cars, motorcycles, trucks or off-road, be it LED, xenon or halogenwww.osram.com
If this the cure for being anxious whilst driving in the dark in the motor home I will be absolutely delighted. I was beginning to think I would have to buy a new mh and order LED lights to get what I wanted.Bad news folks. Just had MoT and... (the naysayers and told-you-sos will love this!)...failed on only two counts, both to do with headlights:
And me...................when I get around to changing them.Ok not fitted yet but hopefully you’ve saved me a fortune.
Just had a word with the man (my daughters neighbor) who MOT'd my car yesterday, can't get the van in his workshop as the road is too narrow but he didn't reckon there would be any problem with the beam pattern after I explained it to him.You might be OK Lenny, if your projector lenses correct the beam sufficiently. Maybe if you can find a friendly garage that will put the beam setters on for you, it can be double-checked before it comes to test time?
Although the video is testing the Osram Night Breaker Lasers, but if your look at his graphs, the Unlimited come out on top
It would be interesting to hear how you get on at MoT time, and would certainly reassure others with projector lenses who’ve opted for the Katurs. Fingers crossed for you.Just had a word with the man (my daughters neighbor) who MOT'd my car yesterday, can't get the van in his workshop as the road is too narrow but he didn't reckon there would be any problem with the beam pattern after I explained it to him.
If you look at the photo's in my post #204 you can see they are hardly any different to the halogens.
Don't know what the latest generations of Nightbreakers are like but the 1st & 2nd gen although good light they had a short life as they are basically an overdriven bulb. Probably not a problem in a Motorhome as you tend to sleep in it a night and not drive.
I used to sell nightbreakers often got complaints about the life, gave up using them in my car as they only lasted 6 months.
The Osram site does suggest that overall life is lower than a normal halogen, so I reckon you’re right. However, the superb lighting while they last, coupled with the point you make about them mostly being off at night makes it worth a go, methinks.Don't know what the latest generations of Nightbreakers are like but the 1st & 2nd gen although good light they had a short life as they are basically an overdriven bulb. Probably not a problem in a Motorhome as you tend to sleep in it a night and not drive.
Really interesting thread and prompted me to have a look around. Philips also make a couple of bulbs (RacingVision and X-tremeVision) which look similar to the Osram bulb(s). In the many reviews of bulbs longevity was compromised so it will be interesting to hear how you get on with them - keep a spare handy!overall life is lower than a normal halogen
I'd have thought you can see the bulb without disassembly.Spoke to my MOT man that does the car (can't do Motormomes), he said providing the headlamp unit is "E" marked and the beam pattern is correct it will pass, they are not going to disassemble the headlamp to check the bulbs, not got time and doesn't think it's allowed.
