Leaving a van on permanent hook up ? (1 Viewer)
pops
544
697
south glos
Pilote panel van
since1997
Never kept any of our vans on EHU. Always take for a 10mile drive every fortnight if not been away. Only hook up the morning we are going and put the fridge on. We used to park in a field on most weekends when we worked, no EHU, no solar panels, 85 amp battery for 3/4 nights from March to November and never had a problem.
Clickem
1,034
1,073
Northumberland
None
7 years
We started off using this method but find that after about 6 weeks (3 cycles) it would not start. Every van is different and if you have alarms and reversing camera it can substantially add to your battery drain
Paddywack
1,211
2,281
Neasham, Co Durham
Hymer ExsisT588
Leave it in the garage on permanent EHU - don't even rewind the cable - I live dangerously me.
Bonio123
23
9
South Wales
3rd year and still enjoying it
Just be aware, left mine on whilst on the drive last year and the house got hit by lightning. Travelled through the EHU and blew all the electrics in the van , both habitation and engine. Thankfully the van was less than three years old so managed to get Fiat and Swift to repair under warranty but I now only connect every couple of weeks when no thunder activity likely and when I'm away on site always disconnect in thundery showery weather
scotjimland
2,335
10,111
A Woosh bang
You could fit a surge protector.. see thread http://www.motorhomefun.co.uk/forum/threads/voltage-surge.110948/#post-1574905
scotjimland
2,335
10,111
A Woosh bang
How easy is is the avs 30 to fit jim :)
Mark
very easy Mark .. took me less than an hour..
I fitted mine above the main switch box in the wardrobe..
Took the feed from the outlet of the DP Main Switch RCD up to the Surge unit, then fed back the 16A MCB
but if you have no electrical knowledge or not 100% happy.. better left to an electrician ..
teensvan99
231
250
Margate
coachbuilt
Never have the van plugged in when at home the 120 watt solar panel keeps both batteries topped up.
When we full timed the van is plugged in at all times when in the freezing UK so yes the blue plug is waterproof otherwise we would have gone BANG every day it P---ed down
steve & ann.------------- teensvan
