Leaking toilet cassette (1 Viewer)
Touchwood
772
733
NE England
Compass Avantgarde 140
5 years and learning
My toilet cassette is leaking - not badly, and only when I take it out to empty it as the leak is around the seal plate where the sliding plate is.
I had a look yesterday and there are two set screws - I removed these expecting to be able to access the seal, but the plate didn't seem to want to come off - didn't want to get rough with it as it doesn't look very strong.
Am I missing something simple?
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Assuming it's a Thetford, all the repair instructions are available in the link below. The plate securing the seal should come away quite easily. I think you have removed only the set screws that are visible at each end of the cover slot. There are more under the side cover plates which have to be prised off carefully - the plastic locating lugs can snap if you are too rough with them.
http://www.thetford-europe.com/en/service/repair-instructions.aspx
The good news is Johns Cross will sell you an overhaul pack with brand new cassette and give you a discount.
jonandshell
5,476
8,299
Not got one!
Is it a C250 by any chance?
Ours tends to spill a little on removal, but we have sussed out this is residue flush water which has gathered above the blade. A quick open and shut of the blade before removal sorts it out!
icantremember
8,338
17,562
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Ours tends to spill a little on removal, but we have sussed out this is residue flush water which has gathered above the blade. [HI]A quick open and shut of the blade before removal sorts it out![/HI]
Beat me to it .......I was going to say the same.
If you forget to do this while it is still in place you can still operate the blade by placing cassette on the ground and turning the orange knob
BUT DON'T FORGET TO CLOSE IT AGAIN BEFORE UPENDING THE CASSETTE:Doh:
Brian
JeanLuc
3,304
2,199
Warwickshire
Same thing happens on my C200. I think a quick open and shut before removal is good practice for all of them.
GJH
29,450
38,827
None, now sold
2006 to 2022
Could be flush water, Mike, that has happened to me. However the seal can lose flexibility with age. Removing and cleaning it in warm water then rubbing it with olive oil can refresh it. They are pretty cheap to replace though. I think Hadrian & Teesside Caravans stock them.
1,710
617
The world
Small car
it is nice having a no handle waste system on the yank tanks
just pop a hose in to the drain and pull a lever no mess no smells and no struggling with a heavy full waste tank or the stinky spillages:Sad:)
when will the Euro vans catch up?
twenty years behind the times
:ROFLMAO::ROFLMAO::ROFLMAO:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
[ame]http://www.youtube.com/watch?v=yda7g3iSaw0&feature=related[/ame]
Touchwood
Touchwood
772
733
NE England
Thanks for the reply; it's not flush water (though what you have described does happen)
I took the empty cassette out, took it to the sink in the utility room at home and filled it with water, then stood it upright to observe that there is a small trickle from around the seal as described.
Now I know how to remove the seal I'll do as has been suggested by Graham, and probably replace it anyway as soon as practicable. It's not a big deal as it doesn't leak whilst in situ anyway.
Thanks to all who responded.
Mike
JeanLuc
3,304
2,199
Warwickshire
Definitely worth replacing the seal as they get hard with age. Also worth buying an aerosol of Thetford Seal Lubricant - it's better than olive oil (but probably not for cooking) and can be used on many different rubber seals, not just the toilet. It keeps seals in excellent supple condition.
< Thetford Seal Lube >
Jim
Ringleader
Jul 19, 2007
36,496
131,206
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I've had more spills and leakages with a marine tank than I ever have with a cassette.:ROFLMAO: Given a choice I'd choose a cassette system every time, I like to empty little and often, rather than pay good money to cart it around with me.
GJH
29,450
38,827
None, now sold
2006 to 2022
Always knew Yanks were full of sh......... :RollEyes::ROFLMAO:
Pikey Pete
1,481
1,143
o
o
Now that is an interesting observation. The Fifth Wheel Company originally had a Black Water Tank but switched to a cassette system.
I had one with the Black tank and frankly I much prefer the cassette system. If you are on a site for a long period and not near a disposal point, with a Black Tank system you have to move the whole vehicle to empty it.
Pete:Cool:
JJ
Mágica
May 1, 2008
19,259
48,061
Burstner Privilege T
over 50 years
I have a 25 year old Euro van and it has that system... no doubt the Yanks copied it... :ROFLMAO: :ROFLMAO: :ROFLMAO:
OSOTOH
JJ :Cool:
