Leaking mixer tap (1 Viewer)
Brisey
Sep 4, 2007
8,087
17,512
Sutton on Sea
Since 2003
Our mixer tap is leaking from its main body, possibly frost damage.:cry:
I am led to believe that these units are non repairable, is this correct.???
Any advice or pointers would be much appreciated.
Brisey
Mikemoss
177
52
Corsham, Wilts
C class
Hi Brisey
Would you believe it - we have exactly the same tap and exactly the same problem. Just dropped ours off at Pickwick Caravans near Melksham for repair/replacement. I'll keep you posted but would expect it to be a new tap.
S
sinbad1
Take the lever off , see if the valve needs tightening up:Smile:
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Brisey
If all else fails, we have these in stock, £45 less 5% Funster discount
Link Removed
scotjimland
2,334
10,102
A Woosh bang
In my experience caravan taps are overpriced and not nearly as good as a domestic.
Our's broke a couple of years ago, mixing handle came right off, but rather than replace with another van tap I bought a chromed, solid brass domestic mixer from B&Q .. wasn't a lot cheaper but far superior quality ...
unfortunately if you have micro switch taps you've got no choice..
JockandRita
11,462
150,162
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Link Removed
Hi John,
That looks exactly like out mixer kitchen tap, made by Reich, as fitted to our Hymer. It is micro switched.
We were quoted almost £90 for a replacement, :Eeek: but can't remember who from.
I managed to source a contact at Reich for spares, when we were at the Dusseldorf show, as all we needed was a new micro switch and a flipper. :thumb:
Jock.
S
sinbad1
Hi John,
Jock.
sell them Link Removed
£48
Regards
Sep 23, 2007
1,710
1,970
Leicestershire
4 and many as a tugger
I had two off these fail in a Swift c/van fortunately they were replaced under warranty.
Surely there is a design fault, or are they a cheap tap sold at a high cost.
Andy
alf
66
South Yorkshire
PVC
Taps
Brisey we have a autosleeper Symbol our tap leaked a year ago I repaired it and touch wood it is still ok.
Remove the tap top lever by slackening the recessed allen screw undo the locking ring holding the spout and slide upwards the spout body in the bottom the was a plastic washer which had split I could not get a replacement so I superglued it it looks like a flat O ring.
I greased the tap with washing up liquid to get the spout body back down it took some pushing.:ROFLMAO:
remember to switch the pump off.
Regards Alf
Mikemoss
177
52
Corsham, Wilts
C class
I've just said thanks Alf, but sadly your instructions on how to remove the top of the tap came too late to save me a bill from Pickwick Caravans! I couldn't work out how to get inside our faulty tap and didn't want to make a relatively minor leak much worse just before the Easter hols.
Anyway, Pickwick have replaced the tap, moved the new one to a better position so we can now close the sink cover, and sorted out a problem with the gas part of our water heater so all's well that ends well.
Will remember your repair tips next time we have any bother, though.
lorger
9,661
90,507
Dumfries
Knaus Sun 650MEG
Hi I have a leaking pigtail for one of these taps do you know where i can get a replacment as only seem to sell the full thing
Mar 29, 2010
438
208
Hebden Bridge
Moto Trek Xcite EB
Since Sept 2011
We have similarly had leaky tap problems and having managed to get it apart have not been able to find the problem, I suspect it is in the bit you can't get too easily. Unfortunately JC don't stock the tap we have and I am reluctant to fit a different one so have forked out for an exact replacement from another supplier without the 5% discount. Spares are available for these taps from
Drew
