Laptop will not POST test ;( (2 Viewers)
savantuk
735
42
Cumbria, Lake district UK
30 years.
Hi,
My laptop has expired! It switches on, the HD begins to spin, and then it stops.
Terminal??
It's an IBM T60.
I'd appreciate any ideas.
Molls-Phot
113
36
Lee-on-Solent
Swift Rio 340
Since November 2009
Had this happen with my MacBook Pro. Logic board kaputten! Would have cost circa ÂŁ250 but they replaced it for free although not under guarantee.
2,338
10,142
Same thing happened to my 10 month old Sony .. HD was stuffed, replaced under warranty ..
jim
Jul 29, 2007
6,551
39,666
Ipswich
RV and PVC
30 years
I think and I might be wrong here, but if it won't do POST then its the MB not the HD as the POST is built-in to ROM on the board.
Olley
43,331
49,483
the graphics board on my desktop is shot.
it boots to the point where it should start the graphics then clicks and shuts down the HD.
Hi,
Terminal??
It's an IBM T60.
Pull the battery just in case that is tripping the power supply.
The good news is that laptops have never been cheaper.
Hi Brian,
I've just tried it, but still FUBAR'd:ROFLMAO:
Welcome to the club. Mine died earlier this year. I stripped it but it was impossible to trace the the power supply - bits all over the motherboard. That was 3 years old and ÂŁ1K and to replace it ÂŁ300.
But you are not dead yet - is this any use:
Is there any sign of life after it shuts down or might it just be the power supply ?
SadGeek
4
West Midlings
AutoTrail
Do you get any error at all, or just a blank screen?
Try getting the laptop to re-recognise the hard drive. Remove the hard drive *completely* from the laptop (should be screw-accessible underneath or from the side, beneath a plastic panel). Power it up without the hard drive in, letting it get as far as it can. Remove power, reinsert the hard drive, and power back up again. If you're really lucky the drive will be recognised and you'll be able to boot.
If a miracle does happen, make a copy of anything that's dear to you, as it is likely to fail again :Sad:
savantuk
savantuk
735
42
30 years.
Hi,
Nothing at all on the screen. I did as you suggested, and removed the HDD.
Still nop luck.:cry:
S
sinbad1
I assume you get no beeps and no error messages ?
Have you removed the battery and used mains only as previously suggested ?
Could be a power supply self test issue if there is a problem there then your lappy will power off to protect the system.
savantuk
savantuk
735
42
30 years.
Just tried it, but no joy. Thanks anyway.
lunarman
2,156
2,451
South Glos
since 1994
Has the boot sequence been changed in the bios? Switch on and hold f1 (i think) to get into the setup and make sure that it is booting from the hard drive
meanders
Funster - Life Member
2,615
8,462
Ipswich, Suffolk
I don't know this machine, but if you can pop the case and get to the motherboard (Possibly needs special tools), look for a button battery (often a CR2032) and change it. On some models, the bootstrap is on a CMOS which needs at least some power. For the price of a battery its worth the effort. However you would have to reset all the BIOS settings.
You could also try (carefully) removing the main CPU and any peripheral cards etc. It should then POST. If it does, your CPU has had it but you might find a replacement cheap.
Robin
des
128
south staffs
RV
5 years
my netbook failed recently. no boot, no nothing, just a quiet whirring sound. turned out to be a bios fault, which i discovered after google research. had to download some software onto a memory stick, then use a special startup sequence. worked for me. unlikely to be your problem, but you never know.
des
acdcdave
Oct 23, 2008
95
75
The trouble with laptops
Doug
What you normally have to do is get into the machine and disconnect everything except the motherboard/processor, one stick of RAM and the power supply. If this all works the machine should POST with two beeps. POST problems often come up with various characteristic selections of beeps or no beeps. The latter is non trivial but fixable if the expense of new M/B, processor or PS is worth it for age/capability of machine. When it then POST's you can plug in the hard drive, optical drives etc until you find and then isolate any higher level problems.
The most important thing is you need access to a working PC so you can Google the problem and go through the excellent forums which will guide you through the options. It's usually something very basic at this level, the tricky stuff tends to happen after POST is completed. This is all fine for DESKTOPS but for laptops its a real workshop job since everything is so compressed and specialist tools are required. In the US you can find laptop spares shops and get bits but it's real tough over here. In a desktop this is all doable and is one of the reasons I would never be without a desktop or two.
I guess you need a reliable laptop specialist to have a quick look and give you an opinion as to whether it's worth fixing.
Good luck, Dave
scept1c
9
Holywood
Hi Doug,
I have a T60 and I also have some pdf guides to trouble shooting and the Hardware Maintenanace Manual HMM, if you send me an email with your email address I can send them to you if you like. About 7mb download.
If you press the blue button can you get into the BIOS or do you hear any beeps. If not, you may have a problem with the display or its connection. You might like to try connecting a monitor to check.
If you're not getting any beeps, you could try opening it to reseat the memory dimms. If you do this, make sure you ground yourself to avoid any ESD problems.
GJH
29,450
38,827
None, now sold
2006 to 2022
Must be catching as a similar thing happened to my Acer Aspire One netbook on Monday. As it is only 9 months old we took it back to Comet and they have sent it to Acer for a warranty repair.
Graham
steveheather
23
Bourne, Lincolnshire
C Class Low Pro
8 Years
Hi, I'm a regular reader but I think this is my first post!
For those who have a sudden boot up problem with an Acer Aspire One, there is a common and well documented issue with earlier versions of these netbook models. A read of this post will describe the fix which I guess is the issue alluded to by des above:-
I have had an AA1 for about a year now and suffered the 'black screen of death' 5 times in all. The 'fix' described in the above link has worked each time. I am guessing that the problem suffered by GJH is perhaps the very same issue.
The problem is found in AA1's loaded with an older BIOS. Upgrading the BIOS to one of the recent versions (3310 is the latest to date) fixes the problem finally. BIOS upgrades and instructions can be found here:- http://macles.blogspot.com/ Of course, BIOS upgrades can also be found more directly through Link Removed
Sorry to shanghai the original post a little but this will undoubtedly help some members.
Steve
GJH
29,450
38,827
None, now sold
2006 to 2022
Thanks Steve, that could well be the problem. I've just had a look at the Acer page you listed (and bookmarked it) and see that the BIOS on my machine (it says 3114 on the box) is the oldest they list for the AAO 150. It will be interesting to see what the repair report says when I get the machine back.
Graham
scept1c
9
Holywood
Hello again Doug, since you didn't respond to my offer to send you the Trouble Shooting guide and IBM T60 Hardware Maintenance Manual HMM pdf files I have concluded that you prefer not to pass on your email address. I can understand that considering your previous profession. If you still have the fault, have a look at the possible causes below.
I've cut/pasted the possible actions for No-beep symptoms.
No-beep symptoms
Symptom or error
FRU or action, in sequence
No beep, power-on indicator on, LCD blank, and no POST.
1. Make sure that every connector is connected tightly and correctly. 2. DIMM. 3. System board.
No beep, power-on indicator on, and LCD blank during POST.
1. Reseat DIMM. 2. System board.
The power-on password prompt appears.
A power-on password or a supervisor password is set. Type the password and press Enter.
The hard-disk password prompt appears.
A hard-disk password is set. Type the password and press Enter. Symptom-to-FRU index
It's quite easy to reseat the memory dimms if you want to give it a try but it would be easier having the HMM guide. I repeat my previous message to ground yourself to prevent problems associated with Electro Static Discharge ESD if you are checking dimms or connectors.
HTH Feel free to contact me if you would like any more info.
savantuk
savantuk
735
42
30 years.
No-beep symptoms
Symptom or error
Sorry not to have replied earlier, but I've just noticed this post is active again.
I'd be most grateful for any help you can offer.
My email address is dougdarterATaol.com
Thanks,
Doug
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Because you are a super star in repair docket fortune telling:thumb:
Pm me next weeks lottery Numbers please Graham:thumb:
GJH
29,450
38,827
None, now sold
2006 to 2022
You know me Geo, don't like to boast ::bigsmile: But why did you add "in repair docket fortune telling"? You must have realised the sentence was complete without it surely :ROFLMAO:
Graham
