Laptop will not POST test ;(
Discussion in 'Computers' started by savantuk, Dec 5, 2009.
  1. savantuk
    savantuk Read Only Funster
    Jul 3, 2009
    751
    34
    Cumbria, Lake district UK
    Hi,
    My laptop has expired! It switches on, the HD begins to spin, and then it stops.
    Terminal??
    It's an IBM T60.
    I'd appreciate any ideas.
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,952
    17,633
    YO11 2BD
    if it gets far enough try booting in safe mode.
    but by the sound of it, its not even getting to boot mode.:Sad:
  3. Molls-Phot
    Molls-Phot Funster
    Oct 8, 2009
    71
    16
    Hampshire
    Had this happen with my MacBook Pro. Logic board kaputten! Would have cost circa £250 but they replaced it for free although not under guarantee.
  4. savantuk
    Jul 3, 2009
    751
    34
    Correct, it's not getting to boot mode, so I can't even start it in safe mode:(
  5. scotjimland
    Jul 25, 2007
    28,935
    25,613
    Same thing happened to my 10 month old Sony .. HD was stuffed, replaced under warranty ..
    jim
  6. olley
    olley Funster
    Jul 29, 2007
    3,775
    2,304
    Ipswich
    I think and I might be wrong here, but if it won't do POST then its the MB not the HD as the POST is built-in to ROM on the board.
    Olley
  7. pappajohn
    Aug 26, 2007
    29,952
    17,633
    YO11 2BD
    the graphics board on my desktop is shot.
    it boots to the point where it should start the graphics then clicks and shuts down the HD.
  8. hilldweller
    Dec 5, 2008
    27,288
    26,279
    Macclesfield
    Pull the battery just in case that is tripping the power supply.
    The good news is that laptops have never been cheaper.
  9. savantuk
    Jul 3, 2009
    751
    34
    Hi Brian,
    I've just tried it, but still FUBAR'd:Rofl1:
  10. hilldweller
    Dec 5, 2008
    27,288
    26,279
    Macclesfield
    Welcome to the club. Mine died earlier this year. I stripped it but it was impossible to trace the the power supply - bits all over the motherboard. That was 3 years old and £1K and to replace it £300.
    But you are not dead yet - is this any use:
    http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-62465
    Is there any sign of life after it shuts down or might it just be the power supply ?
  11. SadGeek
    SadGeek Read Only Funster
    Dec 5, 2009
    4
    West Midlings
    Do you get any error at all, or just a blank screen?
    Try getting the laptop to re-recognise the hard drive. Remove the hard drive *completely* from the laptop (should be screw-accessible underneath or from the side, beneath a plastic panel). Power it up without the hard drive in, letting it get as far as it can. Remove power, reinsert the hard drive, and power back up again. If you're really lucky the drive will be recognised and you'll be able to boot.
    If a miracle does happen, make a copy of anything that's dear to you, as it is likely to fail again :Sad:
  12. savantuk
    Jul 3, 2009
    751
    34
    Hi,
    Nothing at all on the screen. I did as you suggested, and removed the HDD.
    Still nop luck.:cry:
  13. sinbad1
    sinbad1 Deleted User
    I assume you get no beeps and no error messages ?
    Have you removed the battery and used mains only as previously suggested ?
    Could be a power supply self test issue if there is a problem there then your lappy will power off to protect the system.
  14. savantuk
    Jul 3, 2009
    751
    34
    Just tried it, but no joy. Thanks anyway.
  15. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,472
    884
    South Glos
    Has the boot sequence been changed in the bios? Switch on and hold f1 (i think) to get into the setup and make sure that it is booting from the hard drive
  16. meanders
    meanders Funster - Life Member Life Member
    Jun 28, 2008
    569
    342
    Ipswich, Suffolk
    I don't know this machine, but if you can pop the case and get to the motherboard (Possibly needs special tools), look for a button battery (often a CR2032) and change it. On some models, the bootstrap is on a CMOS which needs at least some power. For the price of a battery its worth the effort. However you would have to reset all the BIOS settings.
    You could also try (carefully) removing the main CPU and any peripheral cards etc. It should then POST. If it does, your CPU has had it but you might find a replacement cheap.
    Robin
  17. des
    des Read Only Funster
    Oct 1, 2007
    128
    south staffs
    my netbook failed recently. no boot, no nothing, just a quiet whirring sound. turned out to be a bios fault, which i discovered after google research. had to download some software onto a memory stick, then use a special startup sequence. worked for me. unlikely to be your problem, but you never know.
    des
  18. acdcdave
    acdcdave
    Oct 23, 2008
    96
    75
    The trouble with laptops
    Doug
    What you normally have to do is get into the machine and disconnect everything except the motherboard/processor, one stick of RAM and the power supply. If this all works the machine should POST with two beeps. POST problems often come up with various characteristic selections of beeps or no beeps. The latter is non trivial but fixable if the expense of new M/B, processor or PS is worth it for age/capability of machine. When it then POST's you can plug in the hard drive, optical drives etc until you find and then isolate any higher level problems.
    The most important thing is you need access to a working PC so you can Google the problem and go through the excellent forums which will guide you through the options. It's usually something very basic at this level, the tricky stuff tends to happen after POST is completed. This is all fine for DESKTOPS but for laptops its a real workshop job since everything is so compressed and specialist tools are required. In the US you can find laptop spares shops and get bits but it's real tough over here. In a desktop this is all doable and is one of the reasons I would never be without a desktop or two.
    I guess you need a reliable laptop specialist to have a quick look and give you an opinion as to whether it's worth fixing.
    Good luck, Dave
  19. pappajohn
    Aug 26, 2007
    29,952
    17,633
    YO11 2BD
    more to the point......doug reported this problem over a month ago.
    do you get it resolved doug?????
  20. scept1c
    scept1c Read Only Funster
    Feb 22, 2009
    9
    Holywood
    Hi Doug,
    I have a T60 and I also have some pdf guides to trouble shooting and the Hardware Maintenanace Manual HMM, if you send me an email with your email address I can send them to you if you like. About 7mb download.
    If you press the blue button can you get into the BIOS or do you hear any beeps. If not, you may have a problem with the display or its connection. You might like to try connecting a monitor to check.
    If you're not getting any beeps, you could try opening it to reseat the memory dimms. If you do this, make sure you ground yourself to avoid any ESD problems.
