Laptop Charger (2 Viewers)
ShiftZZ
21,383
84,580
Dark Side of the Moon
I have an Igo laptop charger 12v and recently I have changed to a HP laptop and there are no connectors produced for this model, I am most disappointed as it has served me well.
I have never really go on well with inverters, but, it would appear that I may have to bite the bullet and get an inverter, suggestions?
D
Deleted member 29692
Which HP model is it @ShiftZZ?
There are 12v chargers around for some HP models.
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
Find a defunct 230v HP charger (eBay spares & repairs?) and cut the laptop connector off the end, leaving enough wire for splicing.
Buy a suitable 12v charger (ie correct output voltage/ampage) and cut off whatever universal-type connector it has on the end.
Solder HP connector to 12v charger cable, taking care to get polarity right (insulation on positive wire is often striped).
I've done something similar and it's worked.
Gellyneck
9,235
18,212
Scotland
More than toes wet now!
Did similar when Acer charger cable got damaged. Cut and spliced together.
However you can get 3rd party multi-tip chargers that will fit HP Compaq kit. Think mine is a Trust.
Jul 2, 2011
953
492
UK
Swift Kon Tiki Tag, 2007.
Newbie
If the OP doesn§t mind, can I ask a question about 'charging'a laptop with a basic inverter.
I understand it should be a pure sine wave to 'run' a laptop, but if the laptop is turned off and the inverter is just being used to charge the battery, while travelling for instance. is that OK?
scotjimland
2,335
10,108
A Woosh bang
hmm.. it may well be ok.. do you feel lucky ?
200 watt Quasi sine wave about £40 .. PSW about £100
I wouldn't risk charging almost £2.5 k of laptops for the sake of about £60 more for the PSW ... would you ?
GJH
29,450
38,827
None, now sold
2006 to 2022
You can use a 12v car charger like this
Broken Link Removed
That's similar to the charger I've been using for years but sometimes laptop manufacturers use different sockets which the supplied tips do not fit. I had to buy a specific charger for an Asus laptop a few years ago as a result. When buying a multi-charger it is important to ask the seller if it has a tip for the specific machine you want to charge.
movan
21,492
120,753
Moving around
Burstner
since07
Don't know but if you get one from Maplins make sure it doesn't keep screaming at you when you switch it on ... mine does. :(
