L300 hight beam (1 Viewer)
Nov 18, 2011
11,862
43,057
Planet Earth
A van
Over 25 year's
cant seem to get high beam on my L300 classic camper will this be on a relay HELP pleas
:Sad::Sad:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Might help if I knew what a L300 was, Mitsubishi maybe??
But in any case yes a relay will be in circuit, but it could just as easily be a switch, fuse or cable fault
Without hands on, all advise will be best guess:RollEyes:
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Little flat nosed van derived, Geo - similar to the toyota lite ace.
I would say on this age of vehicle, you are probably looking at the stalk switch that has failed
Wildbill
Nov 18, 2011
11,862
43,057
Planet Earth
A van
Over 25 year's
yes Mitsubishi the swich on stering wheel ok or stack swich is ok
Apr 13, 2012
5,545
18,776
Mobilvetta Euroyacht
1996, then break 'til 2011
Happened to me last year - it was the stalk switch (04 Ducato) - after flicking the switch a few times it worked normally.
I then realised that MHs rarely travel at night, especially in winter and that the contacts on the switch were probably just dirty or corroded through lack of use.
Wildbill
Nov 18, 2011
11,862
43,057
Planet Earth
A van
Over 25 year's
Have you tested it with a meter? Usually, they wear internally.
Failing that, look for the relay.[/QUOTE
got it it was dirty switch full of fluff stopping it working clean up with wd40 and electra clean job done
